Silver Member Username: Imi4tth3wSan Antonio, Texas USA Post Number: 187 Registered: Feb-07 | anyone ever done it? i was looking at a couple threads and it sounds like it would work pretty well but i don't want to completely fck my car. but its WAYY cheaper than dynomat. any suggestions? |
Platinum Member Username: WingmanaliveA pic is worth 1000 posts!! Post Number: 17705 Registered: Jun-06 | As in roofing ice guard? |
Gold Member Username: SouthernrebelMonroe, Louisiana 3 DD3515s, 2... Post Number: 6600 Registered: Mar-04 | IIRC, Ice Guard is the same stuff as Peel-n-Seal. If so, yes it works. I have 3 layers of peel-n-seal in my roof and 2 layers on the back wall. Its good even in 100deg Louisiana heat. Just make sure you clean the surface w/ acetone before you apply it. |
Platinum Member Username: WingmanaliveA pic is worth 1000 posts!! Post Number: 17708 Registered: Jun-06 | Up north we call it "flashban". The stuff roofers use to seal around vent pipes and chimneys and such. (Did it for 7 years). Tar base with a flexible metal backing. Form it around and blow torch away. Very sticky. |
Gold Member Username: SouthernrebelMonroe, Louisiana 3 DD3515s, 2... Post Number: 6605 Registered: Mar-04 | Also, if it is cool outside...use heat gun to warm it up before appling. |
Bronze Member Username: LoudnproudPost Number: 32 Registered: Jul-08 | wow, I was googling "peal&seal car audio" and look what came up https://www.ecoustics.com/electronics/forum/car-audio/153137.html |
Gold Member Username: SouthernrebelMonroe, Louisiana 3 DD3515s, 2... Post Number: 6606 Registered: Mar-04 | Lol...that's me |
Bronze Member Username: LoudnproudPost Number: 33 Registered: Jul-08 | figured it was. Username: Southernrebel on both this and that thread |
Silver Member Username: QuirkySA, Texas Post Number: 296 Registered: Feb-07 | Sounds like it's worth giving it a try. Let me know when you are planning on installing it. |
Silver Member Username: Imi4tth3wSan Antonio, Texas USA Post Number: 189 Registered: Feb-07 | peel and seal? i'll have to take a look at it i want to try it but i'm worried about having that stuff permenatly in my car. i think i might just do a test and put it in the doors and see how that works out for me and if all goes well i'll do the rest of the car. damn tahoe is gonna need quite a bit of it. |
Gold Member Username: JkidderWorlds gunna end, In 2012 Post Number: 3732 Registered: Nov-05 | i use peel and seal. works fine for me. not a huge help but it is definitely an improvement the cisco kid |
