2000 watts and 800 dollars
Username: Basshead33
i have 800$ for sub/subs and 2000 watts at 1 ohm. i have 10 cu ft to work with and want vision blurring intestine rumbling bass. loud and low. mainly in the 25-40hz range. will go sealed or ported, any number and size of speakers
Username: Loudon
Post Number: 2578
rd alpha 15/ rd 1750.1
4 cubes to 32 hz ...
Post Number: 8
i have the amp already, so im just lookin for subs
Username: Hittin1
Lake Charles, La. United States
Post Number: 899
what amp? Any elecrical upgrades?
Post Number: 9
hifonics 2007, stock electrical, but pushed 2 arsenals pretty well so i think it's givin off good power. very little dimming
Username: Joebruce
TC Sounds/DLS
Post Number: 2302
If your amp really does 2000wrms then look at these subs
http://www.audioque.com/aq/HDCSeries.htm
2 15s would be loud as f*ck.
Username: Hittin1
Post Number: 901
okay... BXi-2007 puts out about 1600wrms.. A little less with stock charging.
2 AQ sdc2.5's 15's would sound nice and get loud
Post Number: 10
im convinced that it's putting out at least close to 2000, and i want some headroom on the subs.
i looked at the hdc but i thought they didn't do as well on lows. any experience with the 18" version?
Username: Theweasel
2 12 FI SSD, Colorado U.S. of A
Post Number: 1220
try 2 18" rl-p's sealed from soundsplinter. tell me how they are cuz im looking at gettin some
Post Number: 11
i think i'm leaning towards 2 15's and here are some i was considering
fi q
re sx
ss rl-p
treo ssi
dd 3500
or maybe 1 good 18 like
hdc 18
fi btl
fully loaded bl
re sx
fi q
Username: 04redmach1
Es DEALER, GA USA
Post Number: 2217
Off of the amp you are using, the new RD Audio Sonance would be a pretty nice way to go. Tune her low and let it rip. 5.5-6 cubes total and you will be fine. It will also save you some money as well :-)
Kevin
Username: Tatonka
-[Team Audible Insanity]-
Post Number: 2059
It does out out about 1600 at 14.4v.
Bu then u gotta realize you will not always be at 14.4 and box rise will factor in also.
Username: Hittin1
Post Number: 902
2- ssi's would SLAM!! TREO FTW!
Honestly your really couldn't lose with any of your above choices.. Enclosure and install considering.
Username: Jakeyplaysbass
St. Louis, MO / ASU
Post Number: 3264
"im convinced that it's putting out at least close to 2000, and i want some headroom on the subs."
Wrong. On a stock electrical ud be lucky to get 1300-1400rms. As Nicky V said ~1600rms at 14.4v... you are probably looking at closer to 12.5v or lower with that amp on your electrical. Its physically impossible for it to push out 2kw.
Username: Hdubb
Team Revolution
Post Number: 3858
actually u sonance 18s would be a good deal. as far as a single 18 I think the rl-p would be a great choice.
Username: Th3pwn3r
I compensate...
Post Number: 8479
If his batteries were floating at 14.4 it would be possible.
Username: 420alldaylong
Post Number: 3791
That amp would be a good match for
2 RE SE 15" D4
8cf. at 34Hz
Username: Nd4spd18
Northwest PA
Post Number: 8067
Still wouldn't happen..... those amps are overrated by 20-30%
Username: Prozack52
Cincinnati, 2-audio puls...
Post Number: 432
2 d615d4 diamonds ported
Post Number: 12
voltage on my battery takes about 15minutes of hard playing to drop below 14.
is there anywhere i could get an re xxx 18 for less than a grand?
Es DEALER, GA USA
Post Number: 2220
I actually carry RE, and there is no way possible to get a new one for less than a G. It isn't worth it anyways.
Kevin
Username: Surferdude9371
Im BTL Bumpin
Post Number: 1097
i can vouche for the 18BTL getting loud as hell im running 2500 at 35hz so bout the same as you
Post Number: 13
would 2 15" re xxx be worth a grand? i can maybe get some used for 500 a piece
Username: Snowball123
West Allis, WI United States
Post Number: 939
yeah but aren't they rated at 2000 a piece?
Username: Loc_out
SOCAL2 RE 15 XXX
Post Number: 2345
Tim if you are talking of the new RE XXX You our of your mind. Even if you are talking about the 04/05 XXX you would be underpowering them. You should start with a HO alt and work from there. Or with a single sub setup. On a side note i would power a XXX with a BXi-2007.
