Gold Member Username: Drsmith
Montana
Post Number: 2674 Registered: Nov-04
Posted on I'm about to start piecing my system together AQ 2200 2 HDC3 12s and I was curious if any of you had the link to the site that showed what odyssey battery was compatible with your car. Thanks accidentally posted in amplifiers too |
Gold Member Username: Th3pwn3r
I compensate...
Post Number: 8483 Registered: Jul-06
Posted on Hopefully your charging holds up to the demands of that amplfier. |
Montana
Post Number: 2675 Registered: Nov-04
Posted on It should I've emailed DJ back and forth and talked with various people on Soundpressure (the DD forum) and they said it should be alright just need to make sure I'm buying the right battery |
