Bronze Member Username: BouttepPost Number: 52 Registered: Apr-06 | i just bought a sv 360 premier i cannot load the new bin on any of the usd slots please help |
Platinum Member Username: NydasPost Number: 11261 Registered: Jun-06 | Are the file names on the USB drive readable? |
Bronze Member Username: Pdee333Post Number: 71 Registered: Nov-07 | Nalin, you have the patience of a saint. With all the insults and rude people on here, I'm amazed you still bother. I do appreciate the help you've given me though.. Thanks always |
Bronze Member Username: BouttepPost Number: 53 Registered: Apr-06 | nalin i can't even get acces to usb content , when i choose pvr , it gives me usb and pvr , when i click on usb it gives me front or back , i tried both and gives me please wait then nothing back to the menu screen , but my sonicview 4000 reads the same jump drive perfetly any idea ( the receveir in brand new out of the boxe ) |
Silver Member Username: GregrafPost Number: 989 Registered: Dec-07 | Ya a Saint Bernard maybe.![]() |
Bronze Member Username: BouttepPost Number: 54 Registered: Apr-06 | nalin tried a force loading with no succes i get no disk found any idea ? can u get me instructions for cable loading thanks |
Bronze Member Username: Perycles2005Post Number: 67 Registered: Mar-05 | Hey some of us know when some one has been a real help...you guys trying against Naylin that;s because don't have a clue of what Naylin can do...show what you can to help others first and then talk... |
New member Username: JoeflemingheaderPost Number: 3 Registered: Jul-08 | I have heard of the great Nalin Nyda, he is a legend. Is he a member here?? Love to finally meet him, I would not know what to say..blush ![]() |
Silver Member Username: GregrafPost Number: 990 Registered: Dec-07 | Congrats Thats two more LOSERS in the Nalin Nyda fan club. |
Silver Member Username: GregrafPost Number: 991 Registered: Dec-07 | Legend your gonna make me fall off my chair you plug.![]() |
Platinum Member Username: NydasPost Number: 11262 Registered: Jun-06 | joe damas: Sonicview SV-360 Remove Device Safely function in USB Menu before removing USB drive Format USB thumb drive before loading software '" Your receiver may be programmed for use of ext2 partition (Linux type) and not NTFS or FAT32 commonly found in windows '" see Paragon Partition Manager below for formatting. Google this name and you will get alternative sources of free downloads. http://www.partition-manager.com/ To view ext2 partitions : http://sourceforge.net/project/showf...group_id=43775 http://www.brothersoft.com/downloads/ext2-partition.html You may also need a .trp file viewer if you are going to use the ext2 type format for video files downloads http://www.cccp-project.net/ When extracting from a zipped source, always extract to your regular hard drive and then transfer the file to your pre-formatted USB drive. |
