ViewSat Ultra - Good S, but 0 Q
Username: Hekevin
I installed a new ViewSat Ultra receiver, with DishNetwork ~20" dish (500). I aimed to Galaxy 3 and some other satellites, Port 1, 3... got S: 78-80, but Q: 0. No channel at all to view. I read an article said dish has to be 30" or larger. Is this matters? Or should I load some channel list to the receiver?
Thanks in advance!
Username: Plymouth
Quebec city, Quebec Canada
Post Number: 2966
Kevin He
Where are you located(State or Province)?
Username: Hekevin
Northren Virginia, near to DC.
Username: Plymouth
Post Number: 2975
Kevin
You can get this sat with 18" dish
with your location with 20" dish you can get Bev 82.0W, 91.0W, Dn 61.5W, 110"0W, and many Tp on 119.0W and 121.0W
118,7W require 30" dish and bigger.
I give you the setup for 61.5W
LNB Type Standard
LNB high 11250
Tp Freq 12384
With this you can try to aligned your dish.
Buy a cheap Satellite tracker 10$ and you dont need to use a TV on the roof.
If you need more info ask it.
Good luck
Username: Gregraf
Post Number: 988
Sometimes its nice to watch tv on the roof to get away from the old lady.
Username: Plymouth
Post Number: 2978
Lol
Well done Greg
