Gold Member Username: Saqeeb9000
Post Number: 3571 Registered: Oct-07
Posted on any suggestion........... it just say the banned messasge.. any way to get into login page.. |
Bronze Member Username: Jjgee
Palatine,
IL
Post Number: 88 Registered: Apr-08
Posted on Use a proxy IP |
Silver Member Username: Krishn
Post Number: 176 Registered: Sep-06
Posted on Sada: Probably you have a fixed IP address from your ISP. Just request them to assign you a new IP address |
Post Number: 3572 Registered: Oct-07
Posted on i can not get into login page.. it says u are banned. |
Post Number: 3573 Registered: Oct-07
Posted on i will check with internet provider |
