Bronze Member Username: Fahadriz8Post Number: 92 Registered: Aug-06 | Hey guys I have a captiveworks 600s premium reciever, i put in the SV file by mistake which is i believe for the CW-700. Now when i turn on the reciver it says "Boot" anyone have any idea what I can do to watch tv? thnx |
Silver Member Username: DimwittPost Number: 813 Registered: Aug-06 | As it displays BOOT load this: CW600PremiumV1.96 |
Silver Member Username: YomanPost Number: 208 Registered: Feb-07 | That's old file its 1.97 released buddy.. Go to www.crazyfta dot com to get ur latest fix vince carter |
Gold Member Username: PlymouthQuebec city, Quebec Canada Post Number: 2932 Registered: Jan-08 | Go at: http://www.captiveworks.com/downloads.php download "CW-600S Premium Firmware: Version 1.09" Procedure:Power off on rear panel , push and hold front Power button then Power on rear switch and load factory bin, do a hard reboot and load last bin and so again a hard reboot Enjoy ![]() |
Bronze Member Username: Fahadriz8Post Number: 93 Registered: Aug-06 | ok so let me just get it straight this time. First I load the firmware which is the same as the factory bin?. then i just load the latest bin file? thnx guys and its just the 2 files right |
Gold Member Username: PlymouthQuebec city, Quebec Canada Post Number: 2944 Registered: Jan-08 | Right And you need to enable patch with F1 and 000 on remote |
Bronze Member Username: Fahadriz8Post Number: 94 Registered: Aug-06 | alrite i tryed that but when i load the firmwire it sits and 0% and doesnt go anywhere. and the power light is on but the locked light is off, usually the locked light would also be on. any suggestions? |
Gold Member Username: BrucesterPost Number: 1543 Registered: Jul-06 | do your setting then scan your sat then then enable the patch f1 000 |
Gold Member Username: BrucesterPost Number: 1544 Registered: Jul-06 | try this CW600-S PREMIUM Dead Box, No LCD display, Red Light Only -------------------------------------------------------------------------------- Dead Box, No LCD display, Red Light Only, or "I loaded the wrong Software" How To CW600-S PREMIUM RECIEVERS ONLY! This How To is for anyone who has a box that appears to be 'dead'. Possible signs of a dead STB are: Unit will not power on correctly. Unit will not display anything on LCD. Unit only shows a red light on the box. Unit is stuck in boot mode. Unit freezes during boot up. If you are experiencing any of these problems or something very simple then the chances are, you have a dead STB. At the moment, there are no JTAG 'revival' techniques, that will repair dead boxes. However there may still be hope for you. If the receiver can be placed into boot mode, you may be able to fix your broken box by loading the factory software onto the receiver. Things to know before trying to revive a dead box. First of all, if your STB is brand new and has never been updated by anyone, then you need to send your unit in for repair. CaptiveWorks has a 1 year manufacturers warranty on these receivers. Before attempting to 'fix' the problem yourself, contact CaptiveWorks via their website or phone number to see if you can have your box repaired. Secondly, if you have killed your box by loading software onto it "PERIOD", whether this was factory software or not, you have violated your warranty agreement an forfeit any repair work that CaptiveWorks may have previously done for free within the warranty period. If you have only attempted to load factory software and have not attempted to load 'second hand' or 'non factory' software (such as the updates provided on this site), CaptiveWorks "WILL NOT" repair your unit. They are bound by law, not to repair any unit that has been modified to work outside of it's factory parameters. So don't send in your 'patched' unit expecting CaptiveWorks to fix your mistake. It won't happen. Last but not least, the following steps are not guaranteed to revive your STB. This is your last hope of reviving your receiver until a JTAG procedure is developed and even then it may not be possible to fix the problems with your STB. If the following steps do not repair your receiver, let me be the first to congratulate you on your new doorstop. First you must check to see if you can get your receiver to stay in boot mode. This is done by powering off the receiver from the rear rocker switch and powering back on from the rear rocker switch while holding the power button on the front of the receiver. If your receiver continues to display 'boot' on the LCD screen then there may be hope for you yet. If you are not able to get the receiver to continue to show 'boot' but it does show when the unit attempts to turn on, skip all of the following steps until you reach the section labled 'No Boot?' If you do not see 'boot' at all on the LCD screen of the receiver, congratulations, you may now throw your receiver away. Next you will need to load the factory software for the premium receivers onto the box via RS232 Null Modem Serial Cable. YOU WILL NOT BE ABLE TO LOAD ANY SOFTWARE ONTO THE BOX VIA USB TO SERIAL CABLE! There is currently no way for you to load the receiver using a USB to Serial Cable, while the receiver is in boot mode. You will actually have to connect to a serial port on the computer or you will not be able to continue. While the receiver is in boot mode, you will need to load the factory files starting with the V1.08 software, followed by the V3.01 CXLoader. It is best to load these files using the V1.06 software updater, however, the V1.05 updater will work as well. The factory software for CW600-S PREMIUM receivers can be found here [link removed] If you are not able to get the software to transfer, check your settings and try again. If the software will not take, and you are sure that your settings are correct and the cable is good, you may now throw your receiver away. If you are able to get the software to load, attempt to reboot the unit. If the receiver still does not turn on correctly or continues to show signs of being dead, try to load the software again. If you continue to have problems once the software has loaded after a second or third time, congratulations you may now throw your receiver away. If your receiver makes it all the way through the boot up and displays a channel or Menu Screen and you are able to navigate through your settings on the box, do a factory default ('All' option) and load the factory software again followed by another factory default ('All' option) before attempting to load the correct software for the PREMUIM receiver. NO BOOT? If you are unable to get the unit to stay in boot mode, there is one last chance that you may be able to revive your receiver. Connect an RS232 Null Modem cable to the receiver and run the V1.06 software on your computer. You will need the factory software before continuing. This contains both the V3.01 CXLoader and the V1.08 Factory Software. You will need to prepare the updater for loading the V1.08 Factory Software. YOU WILL NOT BE ABLE TO LOAD ANY SOFTWARE ONTO THE BOX VIA USB TO SERIAL CABLE! There is currently no way for you to load the receiver using a USB to Serial Cable (this applies because you are attempting to load the receiver in boot mode). You will actually have to connect to a serial port on the computer or you will not be able to continue. Once everything is ready to update the receiver, reboot the STB. While the receiver displays 'boot' on the LCD screen, press the start button in the updater software on the computer. Hopefully your receiver will start to load the factory software. If your receiver does not start the transfer, attempt this several more times because your timing, may be off and there is not an exact science as to when to press the start button on the software. If you are not able to get the software to transfer, check your settings and try again. If the software will not take, and you are sure that your settings are correct and the cable is good, you may now throw your receiver away. If you are able to get the software to load, attempt to reboot the unit. If the receiver still does not turn on correctly or continues to show signs of being dead, try to load the software again. If you continue to have problems once the software has loaded after a second or third time, congratulations you may now throw your receiver away. If your receiver makes it all the way through the boot up and displays a channel or Menu Screen and you are able to navigate through your settings on the box, do a factory default ('All' option) and load the factory software again followed by another factory default ('All' option) before attempting to load the correct software for the PREMUIM receiver. __________________ hope it helps you |
Bronze Member Username: Fahadriz8Post Number: 95 Registered: Aug-06 | HEY bruce thnx for the info although ur link doesnt work . can u please check it out ? thanx |
Gold Member Username: BrucesterPost Number: 1545 Registered: Jul-06 | i just c/p it from completefta dot com you can get factory bin from the site just regester for free then go to cw files section its all there and for more how tos go to the how to section for cw |
Gold Member Username: Dude123Post Number: 2362 Registered: Jul-06 | Hey bruce, Long time no see how have you been dude? How is crazyfta going? |
Gold Member Username: BrucesterPost Number: 1547 Registered: Jul-06 | i dont help out there at the new site i was not asked but all is good i work a lot in the summer and dont have much time but im doing great thanks for asking hope things are going good for you have a great day |
Gold Member Username: BrucesterPost Number: 1548 Registered: Jul-06 | here you go im in a good mood CW 600S Premium only Factory Bin CW600PV1.09 http://www.ShareCow.com/Download.aspx?request=367b476f-48b2-4639-9258-2e36668eec 1f click on ths and will get the file enjoy |
