Nearly time
Username: Drsmith
Montana USA
Post Number: 2674
I'm about to start piecing my system together
AQ 2200
2 HDC3 12s
and I was curious if any of you had the link to the site that showed what odyssey battery was compatible with your car.
Thanks
accidentally posted in amplifiers too :-(
Username: Th3pwn3r
I compensate...
Post Number: 8483
Hopefully your charging holds up to the demands of that amplfier.
Username: Drsmith
Montana USA
Post Number: 2675
It should
I've emailed DJ back and forth and talked with various people on Soundpressure (the DD forum) and they said it should be alright
just need to make sure I'm buying the right battery
