Help choosing an amp.
Username: Pthekiller05
I need help choosing an amp. I jsut got a pioneer TS-SWX310 shallow mount sub. It's a truck with a crew cab. I've got 2 4" in the front and 2 6" in the back. I'm going to eventually upgrade those to 2 6x9's. I'm thinking on spending about $200-$300. Maybe to $350.
Username: Insearchofbass
Post Number: 9997
It looks like this subwoofer is a single 4 ohm voice coil with a 250 watt rms rating. If thats the case I would suggest this kicker zx 250.2 it will put out 250 rms at 4 ohms bridged and its $102.00 shipped.
http://cgi.ebay.com/Kicker-ZX250-2-Car-Amplifier-2-channel-250W-amp-NEW_W0QQitemZ140252450236QQihZ004QQcategoryZ39732QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Username: Neptune07
Grand Junction/Golden, CO
Post Number: 97
so you just want a mono amp for your sub or an amp for your speakers as well?
I would like to have a amp for all the speakers. So it looks like a 4 channel then?
Username: Neptune07
Post Number: 101
you're gonna need a mono amp for your sub and a 4-channel amp for your speakers.
Kicker 08ZX300.1 for the sub and the amp sean suggested for the speakers.
what HU do you have btw?
Username: Neptune07
Post Number: 102
scratch that last post, i didn't realize he was posted a sub-amp. what kind of speakers do you have and how much power can they take?
Username: Juliob
Santo DomingoDominican Re...
Post Number: 5416
i think a 5 channel will fit your setup because they have a subwoofer channel and 4 regular channels..
i'd look Elemental designs, they have a great 5 channel model.
There's also kicker zx 700/5.
Post Number: 10011
Im not sure how much the elemental design 5 channel is or what power it puts out but you can buy a kicker 5 channel for $230 shipped on ebay. The only thing is its refurbished but they are supposed to look like brand new when that is the case. Its rated 70 watts x 4 and 210 in the subwoofer section at 4 ohms.
http://cgi.ebay.com/KICKER-ZX700-5-5-CHANNEL-SUB-CAR-AMPLIFIER-AUDIO-AMP_W0QQite mZ250272725274QQihZ015QQcategoryZ39739QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
thanks
