Clifford concept g4 600 no valet code please help!
Username: Moorie318
hi i have a clifford concept 600 g4 fitted to my bmw e36 coupe but when i bought it i had no key fob nor any valet code, so i decided to have a poke around behind the glovebox and found there was no fuses in the wires coming from the brain to the battery so i put some in and the hazards flashed a few times then the sirens went off. what i need to know is there any way i can reset the brain and valet code and buy a new remote and then program that in or shall i just get a new alarm? any help would be appriciated
chris
