Bronze Member Username: The_best99Post Number: 38 Registered: Aug-07 | when i scan this satellite it brings in the wrong channels im trying to have it bring in the international ones. it is on the right port and i even just bought a new switch any suggestions? |
Gold Member Username: PlymouthQuebec city, Quebec Canada Post Number: 2875 Registered: Jan-08 | Post your setup They do that with new bin? |
Bronze Member Username: The_best99Post Number: 39 Registered: Aug-07 | sonicveiw sv-4000 SAt. : echo3 LNB Power: on LNB Type: single LNB Freq.: 11250 TP:12326 22khz: off Search Option: all Network Search: on Diseqc: port 1 Motor: disable Leg. Switch: off |
Bronze Member Username: The_best99Post Number: 40 Registered: Aug-07 | yea the most recent bin is uploaded |
Gold Member Username: Saqeeb9000Post Number: 3548 Registered: Oct-07 | how many dishes do u have? |
Gold Member Username: Saqeeb9000Post Number: 3549 Registered: Oct-07 | basically u are matching ur sat let say u choose 61.5 to out side of ur box window by chagning ur port setting.. u should see the same thing and green signal offcourse. |
Silver Member Username: ThemangodPost Number: 592 Registered: Oct-06 | 61.5 has all the international channels? do they have French? |
Gold Member Username: PlymouthQuebec city, Quebec Canada Post Number: 2879 Registered: Jan-08 | Morroco from Africa is French |
Gold Member Username: PlymouthQuebec city, Quebec Canada Post Number: 2880 Registered: Jan-08 | Chris after load a new bin you need to do a hard reboot. If that not work do this All viewsat box Go to Code menu Select Nagra and on Dish 01 06 00 Dish 00 01 00 dish 01 01 00 Delete this 3 provider one by one with F3 on remote "NEW" do same thing with all provider on Bev provider 09 07 00 09 06 00 09 05 00 09 01 00 08 01 00 no need to delete keys load last bin for your box turn autoroll on Keep on Bin and autoroll regenerete keys Resolve problem with lost channel , autoroll, freeze and search signal "Dont load factory bin" Thats erase bad data in the box For box who lost channel and sat setup ENJOY TV TESTED and work fine New issue for problem on Viewsat Thanks Reply if it work Please |
Silver Member Username: BernardmiPost Number: 185 Registered: Dec-07 | Echostar 3 at 61.5 also carries the following French feeds: -TV5 Monde USA -Trace -Télésud TV5 Monde being the best with low compression on video. Very high quality feed. Trace is 100% videoclips. High quality as well and the sound is just perfect. Enjoy ![]() |
Bronze Member Username: The_best99Post Number: 41 Registered: Aug-07 | i did a hard reboot but no avail i have sonicview i can still get to a code menu? how i have 2 dishes 61.5 and 110&119 there not working either i have the same prob with them, but im just interested in the 61.5 |
Gold Member Username: Saqeeb9000Post Number: 3552 Registered: Oct-07 | asically u are matching ur sat let say u choose 61.5 to out side of ur box window by chagning ur port setting.. u should see the same thing and green signal offcourse. did u tried as i mentioned in above post.. |
Platinum Member Username: NydasPost Number: 11199 Registered: Jun-06 | chris: Based on your setup, it is extremely unlikely that the sytem was set up to have DisEqC switch port 1 for 61.5W While you can do such a setup, 90% of the installations have physical connection as: 119W - port 1 110W - port 2 61.5W or 148W - port 3 or 4. Try seting up software to scan 61.5 via port 3 or 4. |
Platinum Member Username: NydasPost Number: 11200 Registered: Jun-06 | I forgot to mention that there is new ECM by DN, so you will have to wait for new BUN |
Bronze Member Username: The_best99Post Number: 42 Registered: Aug-07 | i did the connections myself and i have the 61.5 in the port 1 are you saying that it makes a difference in which port i use for 61.5? |
Gold Member Username: Saqeeb9000Post Number: 3555 Registered: Oct-07 | no chris why u are not able to scan intenrnational channel? if auto scan doesn't work try blindscan.. |
Platinum Member Username: NydasPost Number: 11205 Registered: Jun-06 | Put 61.5W LNB output into DisEqC port 3 or 4, and set it accordingly in your antenna software. |
Gold Member Username: Saqeeb9000Post Number: 3556 Registered: Oct-07 | here is the nice video for sonicview 4000 anteena setup.. ,this might help.. http://www.youtube.com/watch?v=4ycWU6YFvrY&feature=related |
Bronze Member Username: The_best99Post Number: 43 Registered: Aug-07 | ok i got 3 of the channels i wanted, b4u ztv, zcine, so i beleive my settings are fine but im trying for all of the international channels why cant i pickk all of them up now? its very rainy as well |
