Scanning 61.5 brings in wrong channels
Username: The_best99
Post Number: 38
when i scan this satellite it brings in the wrong channels im trying to have it bring in the international ones.
it is on the right port and i even just bought a new switch
any suggestions?
Username: Plymouth
Quebec city, Quebec Canada
Post Number: 2875
Post your setup
They do that with new bin?
Post Number: 39
sonicveiw sv-4000
SAt. : echo3
LNB Power: on
LNB Type: single
LNB Freq.: 11250
TP:12326
22khz: off
Search Option: all
Network Search: on
Diseqc: port 1
Motor: disable
Leg. Switch: off
Post Number: 40
yea the most recent bin is uploaded
Username: Saqeeb9000
Post Number: 3548
how many dishes do u have?
Post Number: 3549
basically u are matching ur sat let say u choose 61.5 to out side of ur box window by chagning ur port setting.. u should see the same thing and green signal offcourse.
Username: Themangod
Post Number: 592
61.5 has all the international channels?
do they have French?
Username: Plymouth
Post Number: 2879
Morroco from Africa is French
Username: Plymouth
Post Number: 2880
Chris after load a new bin you need to do a hard reboot.
If that not work do this
All viewsat box
Go to Code menu
Select Nagra and on Dish 01 06 00 Dish 00 01 00 dish 01 01 00
Delete this 3 provider one by one with F3 on remote
"NEW" do same thing with all provider on Bev provider
09 07 00
09 06 00
09 05 00
09 01 00
08 01 00
no need to delete keys
load last bin for your box
turn autoroll on
Keep on
Bin and autoroll regenerete keys
Resolve problem with lost channel , autoroll, freeze and search signal
"Dont load factory bin"
Thats erase bad data in the box
For box who lost channel and sat setup
ENJOY TV
TESTED and work fine
New issue for problem on Viewsat
Thanks
Reply if it work
Please
Username: Bernardmi
Post Number: 185
Echostar 3 at 61.5 also carries the following French feeds:
-TV5 Monde USA
-Trace
-Télésud
TV5 Monde being the best with low compression on video. Very high quality feed.
Trace is 100% videoclips. High quality as well and the sound is just perfect.
Enjoy
Post Number: 41
i did a hard reboot but no avail
i have sonicview i can still get to a code menu? how
i have 2 dishes 61.5 and 110&119 there not working either i have the same prob with them, but im just interested in the 61.5
Post Number: 3552
did u tried as i mentioned in above post..
Username: Nydas
Post Number: 11199
chris: Based on your setup, it is extremely unlikely that the sytem was set up to have DisEqC switch port 1 for 61.5W
While you can do such a setup, 90% of the installations have physical connection as:
119W - port 1
110W - port 2
61.5W or 148W - port 3 or 4.
Try seting up software to scan 61.5 via port 3 or 4.
Username: Nydas
Post Number: 11200
I forgot to mention that there is new ECM by DN, so you will have to wait for new BUN
Post Number: 42
i did the connections myself and i have the 61.5 in the port 1
are you saying that it makes a difference in which port i use for 61.5?
Post Number: 3555
no chris why u are not able to scan intenrnational channel?
if auto scan doesn't work try blindscan..
Username: Nydas
Post Number: 11205
Put 61.5W LNB output into DisEqC port 3 or 4, and set it accordingly in your antenna software.
Post Number: 3556
here is the nice video for sonicview 4000 anteena setup.. ,this might help..
http://www.youtube.com/watch?v=4ycWU6YFvrY&feature=related
Post Number: 43
ok i got 3 of the channels i wanted, b4u ztv, zcine, so i beleive my settings are fine but im trying for all of the international channels why cant i pickk all of them up now?
its very rainy as well
