Login : Remember Me
Username: Sabrina999
PSP is a main machine of the beginning of new era, convenient and have a cool appearance. So many owner take care of it like a baby. During playing PSP games, we have exprienced the excitation of updating, anxiety of games unworking, heartbreaking of accidantal damage, happiness of buying accesory and satisfying of a perfect game saving. All these feeling are why we like PSP.
I have summarised some of my suggestion about PSP protective technic for your reference. These are my own point,if you agree, pls tell me. If you donot agree, pls tell me your highly advise.
A: About screen
Liquid crystal screen need to protect against cold but hot.So donot put it in the cold place, for example your refrigerator.
Liquid crystal screen should protect against sunshine. Do not let your baby to have sunbathing.
The brightness of liquid crystal screen is closely interrelated with lift span. If you have the habit of playing under a high brightness environment. Pls prepare to shorten your baby's lift span.
Liquid crystal screen should protect against sunshine.Do not let your baby to have sunbathing.
No matter what screen it is, it wonot be in a still mode so long, so pls donot keep it still for too long.
Liquid crystal screen must be protect from weight.Expecially when you clean your loving PSP, pls remember do not scrape your screen with all your strength even if you thought you are strong enough.
B.Keep dust away from your PSP
Are you afraid of dust in your machine? Don't worry,the machine wonot let dust in during play since continously moving.The dust come in is mainly for unmoving.So how to protect? It is simple, pls turn PSP over, put it on back and put UMD on the upside. By doing this,the rate of dust coming in will be down to 1%.
C.For battery
Pls try your best to donot use the outer power,it is not mean charger. It is the best time to charge when only 6% power left. If you saw your PSP power light is flighting,it is time for you to charge. You can play while charging. It won't affect your battery lift expectancy.
