Help mounting tweeters
Username: Buettnerj1
Hi,
Im new to car audio, so please excuse my limited knowledge. I bought a pair of components for my car and im having some troubles now. The midwoofers fit perfectly, but the tweeters are to big for the stock location. I was wondering what you guys think my best option to that will still look good is. I have a 99 grand prix that previously had the bose system in it. The components i got were the phoenix gold rsd 5cs. Thanks
Username: Exige
CDT, Audiopulse Dealer
Post Number: 521
You could cut out the mounting hole to accommodate them...place them in your A-pillars...build a small pod to use for mounting (made out of fiberglass)...there's many options. Would any of those work for you?
