Missing 455
Username: Tankengine
missing 455 on dish anyone else with same prob ?
Username: Rtap
FL
Post Number: 2205
scan the tp to see if it comes in
Post Number: 9
same problem can't find answer
Username: Rtap
FL
Post Number: 2207
please post your set up dish-stb-file-etc
Post Number: 10
on viewsats using latest bin,dp,110 and 119, reads feq 12399 sig strength ok but 0 quality, all other channels work fine 455 has always worked until 3 weeks ago, I have deleated, restored, reloaded rescaned and I'm out of ideas mainly because everything else is OK,any help would be great and I am not a newbee started with direct years ago
Username: Pclady
Somewhere, US Usa
Hi Tankengine,
I have the exact same problem. Just disappeared. I tried all that you did. I even went to Advanced Scan and entered the VPID and APID...nothing!
Have you resolved this issue?
Thanks so much,
pclady
Username: Plymouth
Quebec city, Quebec Canada
Post Number: 2846
Try another site file
