Bronze Member Username: NinjadPost Number: 50 Registered: Dec-07 | IM LOOKING FOR A CHEAP RELIABLE PLACE TO PURCHASE A RECEIVER. ANY IDEA WHERE I CAN LOOK? I HAD BOUGHT FROM FTASAT4LESS BUT I DIDNT ITS NO LONGER AROUND |
New member Username: SveliteistPost Number: 4 Registered: Jul-08 | try kingsatellite.com they are the best as far as reputable service and support. You can't go wrong. |
Bronze Member Username: NinjadPost Number: 52 Registered: Dec-07 | thanks for the response eliteist. appreciate |
Gold Member Username: SatgrlDil Mei DarD a Jaga ... Post Number: 1555 Registered: Oct-07 | hmm i brought alot from ebay its pretty reliable if u buy from a dealer |
New member Username: SveliteistPost Number: 7 Registered: Jul-08 | ebay is fine as long as you check sonicviewusa.com and make sure the party is a authorized SV reseller. If not you can run into warranty issues or worse. Alway's buy from an authorized reseller no matter what brand you buy. Can't go wrong with Sonicview. |
Bronze Member Username: JustforhahasPost Number: 11 Registered: Jul-08 | Honest, dependable, and well established. Many FTA forums sites back and support both these dealer sites. www.globalwholesalers.biz |
New member Username: RivmanSOL Y PLAYA, PR PR Post Number: 4 Registered: Jul-08 | If you do a thorough search, and know exactly what you're looking for, e-bay is the right place. Tip: Always check sellers reputation before you buy. |
Platinum Member Username: NydasPost Number: 11184 Registered: Jun-06 | My suggestion to everybody is to buy from shops from your own country - if you live in Canada buy from Canadian shops and if you live in America, buy from American shops. You will have better consumer protection. |
