New Key
Username: Alime_123
Afgh, Ghazni Afgh
Post Number: 132
Is there New keys?
Thanks
Username: Nydas
Post Number: 11138
You can get new keys at:
[link removed]
Username: Lookekhoshshans_1356
Tehran, Tehran Iran
Post Number: 159
[link removed]
[link removed]
[link removed]
[link removed]
Username: Alime_123
Afgh, Ghazni Afgh
Post Number: 134
hi
new key doesnot work what should i do?
Username: Nydas
Post Number: 11152
These days the usual problems is not key, but BIN. There was ECM 2 days ago and you need to install the latest BIN. If you post your receiver name etc, somebody will direct you to the right BIN.
Username: Alime_123
Afgh, Ghazni Afgh
Post Number: 135
I have Ariza 700
but the new keys donot work
D!SH 0101 - Last Update: 07/12/08 10:00 AM
00: ED 23 BE 74 66 40 A9 0C 09 33 75 EA E4 AD 8D FE
01: E5 C2 01 40 E8 B6 38 4D CF 3A 39 E3 2F 87 43 CD
B3V 0901 - Last Update: 07/08/08 11:30 AM
00: 2F 8B 61 68 C8 73 93 39 EE C1 F6 0F 3E 1D 0C A4
01: 22 DA 38 52 CC C6 5A 6D 36 E7 41 6F 6D 5A 7F 9D
be for it woked . but since July 9/2008 it didnot work.
what should i do?
thanks you
Username: Joecreosta
Post Number: 27
i have ariza 700 and BIN file i have in my ariza is
AA-1
APIver 3.2oe_EU(N)
Boot ver 1.1
16 Feb 2008
i get the keys from the internet the latest keys from tvkeyz dot com but its doesnt working
can someone helping me?
Username: Alime_123
Afgh, Ghazni Afgh
Post Number: 137
hi all
I donot know The new is not work to my Ariza?
can someone help?
D!SH 0101 - Last Update: 07/18/08 09:15 PM
00: 67 2F 02 FC 9A 93 7D 56 24 C1 8A E9 0C 86 34 09
01: E2 1D A9 F7 58 FA FC 1D A7 DD A1 13 45 87 85 81
B3V 0901 - Last Update: 07/18/08 10:25 AM
00: 45 73 E6 0F C0 23 13 12 12 74 1D 99 FF 34 CC 3E
01: 1D 79 09 30 2B 1A F0 84 2E 4C 83 99 6E C1 08 CF
July 19,2008 --->10/15 AM
Username: Justforhahas
Post Number: 16
Those are the latest correct keys. You are NOT having a "key" issue, but are having an outdated "file" issue. Ariza is no longer supporting their receivers with current updated files , so its best you convert it to a Pansat 2700, which has quick new files called "Pariza 2700" files.
Username: Alime_123
Afgh, Ghazni Afgh
Post Number: 138
how can I convert it to a Pansat 2700,
Username: Halo
Toronto, Ontario Canada
Post Number: 563
NEW KEYS AT www.dishkeys.co.nr
Post Number: 17
Here is the instructions, step by step, along with ALL the files you will need to convert.
http://www.ftabins.net/showthread.php?t=12970
c/p
Ariza 700 To Pansat 2700 Jtag Conversion
Ok folks here is the conversion for the ariza 700 to pansat 2700...
Now it is a USE AT OWN RISK and also DO NOT PM ME WITH QUESTIONS there will be a feedback thread started for that....
To start you will need the files provided in this thread/link... Also if you not good with jtag do not try ..
YOU WILL NEED A JTAG AND ALSO A NULL CABLE TO LOAD FILES
Step 1 Read the instructions provided with jtag info.....( a must)
Step 2 when done with jtagging do not turn off machine unhook jtag
Step 3 open up gt rom loader 27.02 and load pansat 2700 factory bin..
Step 4 load the B75_m fileNow when machine done loading it will reboot do not turn off let it show 8"s goin across then stops on last 8 for roughly 30 sec..
now turn off from back and set up loader...When loader ready turn on from back and at first sign of light hit fix on loader..Do this process for all files...
Step 5 open up BL 1.3 loader and load jvvh 209 file
Step 6 load jvvh 209 file
Step 7 load on the jvvh 211 file
Step 8 load the jvvh 217 file
Step 9 load the jvvh 220 ( the whole time using the BL 1.3 loader)
Step 9 Do blind scans of sats.What u will notice is that your display shows 8's on it dont worry about it at this point just enjoy and watch t.v........And yes your ariza remote will work on this conversion......
REMEMBER READ AND FOLLOW ALL INSTRUCTIONS
Lastly load up the Pariza file 276
