Gold Member Username: Saqeeb9000Post Number: 3504 Registered: Oct-07 | just can't decide b.w these two boxes... suggestion from all those people who have those boxes...................i have 1 hr befor i buy.... |
Gold Member Username: Saqeeb9000Post Number: 3505 Registered: Oct-07 | KBOX K2 Xtream IKS Receiver - First Looks This box does support IKS type serial dongle for key sharing over the internet. KBOX K2 Xtream Main Features ▪ Premium Grade VFD displaying 8 character(CH name & Local Time), Recording mode(Record & Play mode), Status Icons (TV/Radio, Dolby Sound, CAS, Sleep, Time manager, Rock Channel and USB contents) ▪ Time Shifting with Internal Storage Memory (Up to 40~50 min) ▪ Recording & Playback with External USB(2.0) Devices ▪ Event Recording by EPG ▪ Recording and Time Shifting Simultaneously ▪ Recording and Playback Simultaneously ▪ Support Extended 9-day EPG ▪ 2 USB 2.0 Host Slot(MP3 Player & JPEG Viewer) ▪ MPEG-II Digital & Fully DVB Compliant ▪ Blind Scan ▪ Multi-LNB Controlled by DiSEqC Control Version 1.0, 1.2 and USALS ▪ Multi-Satellite Search ▪ On-Screen Display with 65535 Color Full Resolution ▪ Favorite Channel Groups ▪ Powerful Channel Control by Favorites, Lock, Skip, Move and Delete ▪ Channel Sorting by Alphabet, Transponder and CAS ▪ Multi-language Supported (OSD & Menu) ▪ Closed Caption Support ▪ Maximum 10,000 Channels Programmable ▪ Multi-picture Display ▪ Parental Lock / Receiver Lock ▪ CVBS Video & Audio Output via RCA ▪ Component Y/Pb/Pr Output via RCA ▪ S-VHS Video Output ▪ Optical & Coaxial Output for Digital Audio ▪ Software & Channel Database Upgrade via RS-232 & USB ▪ Premium Grade Universal Remote Control Specifications Tuner & Channel Decoder Input Connector F-type, IEC 169-24, Female Loop through out F-type, IEC 169-24, Female Frequency Range 950MHz ~ 2150MHz Input Impedance 75U, unbalanced Signal Level -65 to -25dBm LNB Power 13/18VDC, max.400mA 22KHz Tone (22¾2)KHz, (0.6¾0.2)V DISEqC Control V1.0/1.2/USALS Compatible Demodulation QPSK Input Symbol Rate 2 ~ 45 Ms/s FEC Decoder 1/2, 2/3, 3/4, 5/6 and 7/8 with Constraint Length K=7 MPEG Transport Stream A/V Decoding Transport Stream MPEG-II ISO/IEC 13818 Profile Level MPEG-II MP@ML Input Rate Max. 15Mbit/s Video Formats 4:3 LetterBox, 4:3 PanScan, 16:9 Video Resolution 720 x 576, 720 x 480 Audio Decoding MPEG/MusiCam Layer ¥°&¥± Audio Mode Streo/Joint stereo/Mono Sampling Rate 32KHz, 44.1KHz and 48KHz Main System Main Processor Conexant Virgo(32-bit RISC CPU 180 MIPS) Memory Flash-ROM : 2 MBytes SDRAM : 32 MBytes Audio / Video & Data IN/OUT Video CVBS Video Output (RCA) S-VHS Video Output (Mini-DIN) Y/Pb/Pr Video Output (RCA) Audio L/R RCA(Volume and Mute Control) AC-3 Dolby Digital (RCA & Optical) RS-232C 9 pin D-SUB (Male) type, Transfer rate 115Kbps USB USB 2.0 Host Support(2 Slots) RF Modulator RF Connector IEC 169-24, Female Frequency CH 3 : 61.25MHz CH 4 : 67.25MHz Output Channel CH 3 / CH 4 TV Standard NTSC-M Preset Channel CH 3 (or TBD) Software changeable by Menu Front Panel Slot 1 Smart Card Slot 1 USB Host Slot Buttons 3 Buttons (CH UP/DOWN, STANDBY) Display VFD(Vacuum Fluorescent Display) Power Supply Input Voltage AC 100 ~ 250V, 50/60Hz Type SMPS Power Consumption Max. 25W Standby Power Max. 8W Protection Separate Internal Fuse & Lighting protection Physical Specification Size (W x H x D) 260mm X 55mm X 210mm Weight (Net) 1.2 Kg Operating Temp. 0C ~ +45C Storage Temp. -10C ~ +70C |
Silver Member Username: ThemangodPost Number: 581 Registered: Oct-06 | i think for support reasons you might want to go with neosat pro its been doing more up time them nfusion. what did you pick? |
Gold Member Username: Cartier1Post Number: 1930 Registered: Feb-07 | sada how about channel change. it;s slow in nfusion |
Gold Member Username: Saqeeb9000Post Number: 3515 Registered: Oct-07 | ok i picked kbox............since u guys were late for answering my question, and african had kbox, so iwent for kbox, cartier picture quality is way superior than nfusion, all the feautures are same as they used to be on my koolsat 6100. so basically if i ad m khub device to my cs 6100 it would become kbox (kbox extra memory, iks feautres).. cartier channel change is faster on kbox than nfusion, although i just tested standalone fix for dn... iks , i didn't test it yet, but lots of people having problem (kbox team is doing some maintenance ,will be fully functional tomorrow (i hope).. so more test will be being done in next few day,........ i will post more results.. ( i am still learning the box (iks vs non iks).. so hang on here at ecoustics.. and as past and feature. u won't hear any biased report from me..just results... favor the box based on results |
Gold Member Username: Saqeeb9000Post Number: 3517 Registered: Oct-07 | Hero Supporting Group Notice Dear All Kbox users, First of all, we are very sorry for making you inconvenience with our latest fix released at July 11th (v.128 & v.129). In order to optimize our memory stack and make it faster in its related features, we re-organized its data structure from the version of that time. However, with insufficient internal and external test, we could not clear such a bug you are suffering now. By July 16th, we will clear all bugs and release new v.130. If we may not clear it by that time, we will make a release based on the previous stack. For IKS users, please enjoy with v.125 for the time being. Once again, please excuse us and we will meet you with better support soon. Sincerely yours, Hero supporting Group c&P FROM F2ATV........ atleast there is communication, the big part that is missing from nfusion team..} |
Silver Member Username: CntrlaltdelPost Number: 248 Registered: Nov-06 | Neosat's been a good box for me... wish I would have spent the money and got an iPro instead of a Pro with an adapter. The new HIKS isn't running yet with the adapter, but it's up cardless anyway. |
Gold Member Username: Saqeeb9000Post Number: 3518 Registered: Oct-07 | i tried pvr with kbox........... record the program in to my usb for half hr.. played back in the reciever smooth picture.......no problems |
Silver Member Username: KrishnPost Number: 152 Registered: Sep-06 | Well none of them are good enough since none of them are wireless enabled. It is just a pain to spend $ 60-70 for either a power-line network or wireless bridge. They should make it wireless enabled and perhaps charge $20 more in that way it will be a win win |
Gold Member Username: Saqeeb9000Post Number: 3519 Registered: Oct-07 | yeh that was good idea.. i am having problem with kbox with iks.........frequently freezing...and scrambling channel........i have the latest bin, tried everything still no luck.. |
Silver Member Username: KrishnPost Number: 153 Registered: Sep-06 | Perhaps African can help you, unless it is a common problem |
Gold Member Username: Saqeeb9000Post Number: 3527 Registered: Oct-07 | ok last bin iks wasn't working fine, was freezing, i just turned off modem (under option and autoroll on), stand alone kicked in.....and no freezing issues.. bin was again released today, tried with iks.. working good... |
