Strapping 2 alpine MRP-M450's
Username: Neptune07
Grand Junction/Golden, CO
Post Number: 73
my friend has one so i was thinkin if they are "strappable"(if thats the correct terminology) then he could get another and power 2 12" type S's by connecting each of them to separate amps.
thanks for any and all help
Username: Hittin1
Lake Charles, La. United States
Post Number: 704
that amp is not strappable.
"my friend has one so i was thinkin if they are "strappable"(if thats the correct terminology) then he could get another and power 2 12" type S's by connecting each of them to separate amps. "
Why would the have to be strapped to acomplish that?
Username: Bonhamd
TC, MI USA
Post Number: 846
i think that is one of his questions
strapped is putting two amps on one sub correct?
Username: Tatonka
-[Team Audible Insanity]-
Post Number: 1956
Strapping an amp is combining two amps together, one as a master and one as a slave, then running the amps to the sub in the correct way for the amps.
Username: Neptune07
Post Number: 74
what nick said. obviously you don't need to strap amps to connect more than one to a HU but you would need to strap them in order to run them both off the sub output. i'd rather them both be connected to the sub output than seperate outputs that aren't meant for subs, if you get what i'm saying
