Seesat 6000 usb
Username: Chris7777
Post Number: 107
Does anyone know the master code for the parental lock ..i just got this receiver it says in the book the code is 0000 but no dice if any 1 knows it and can share i would appriciate it
Username: Chris7777
Post Number: 108
somebody anybody??
Username: Picanha
East LA
Post Number: 15
Try 999
Username: Gregraf
Post Number: 950
Reset to factory default by loading factory bin. You have to load factory bin file. Seesat-6000-V1-00-Factory File. Then your pin should be 0000.
