Username: Burkan Post Number: 104 Registered: May-06
Friday, July 11, 2008 - 23:53 GMT I'm having problems getting the PVR on SonicView 360 premier to work. my box says "File System not found" "Drive should be DOS file formated" My Hard Drive is Mastor One Touch. Does anyone know how to fix the problem???
Username: Themangod Post Number: 571 Registered: Oct-06
Monday, July 14, 2008 - 00:34 GMT i suggest you go to a forum for more detailed help if you cant find it here. you need to make sure you put the usb hard drive into the usb port the receiver is using and it must be fat32 like my viewsat pro. you should be able to format on the receiver good site for it are [link removed] [link removed] i think your issue might be the format make sure its fat 32
Username: Gregraf Post Number: 943 Registered: Dec-07
Monday, July 14, 2008 - 00:40 GMT
Username: Themangod Post Number: 579 Registered: Oct-06
Monday, July 14, 2008 - 00:51 GMT your the one spamming. he asked for help i gave him. this picture is wanted by no one. your the spammer, but you already know that. if you want more help the sites below have great support for sonicview 360 Premier PVR [link removed] [link removed]
Username: Sveliteist Post Number: 5 Registered: Jul-08
Tuesday, July 15, 2008 - 15:31 GMT format your hard drive with the 360 in FAT32. You can't do it with XP because XP has a 4GB limitation to fat32. Hope this helps.
Username: Nydas Post Number: 11180 Registered: Jun-06
Tuesday, July 15, 2008 - 15:40 GMT KATE: Kate: When you do not know the answer, you do not send people away from this forum. You are deliberately taking people away from this forum. STOP YOUR SPAM
Username: Themangod Post Number: 585 Registered: Oct-06
Tuesday, July 15, 2008 - 22:15 GMT no i am not but i should not have done it that time your this time.. also you posted urls with out bad ones last time good job i was going to stop posting links now! this was before that i have posted none.
Username: Gregraf Post Number: 951 Registered: Dec-07
Tuesday, July 15, 2008 - 22:20 GMT Hey Kate you sicko
