Not getting 8.10 channels
Username: Stormyone072
Post Number: 37
I have installed new bin for pansat 2500 converted to 2700, all 7.0 channels are in and fine but I am not getting anything for 8.10 channels. list is there but i get scrambled bad channel or no signal. am i the only one with this problem? should i rescan 8.1 sat?
Username: Themangod
Post Number: 568
try a hard reboot of your receiver
thats done by turning off the receiver for 2mins
Username: Pansad
Windsor, Ontario Canada
Post Number: 15
im getting the same thing but when im on an echo 8.10 ku i checked my signal and it was 53% so i think the wind may have moved my dish a little and needs re aimed.i know echo 7 is easier to get in and then it takes a bit to get the 8s up high enough
