check all your connection with serial cable make sure your com port is 1 or w/e you have it setup for after that if that doesnt fix it go bk to quare one reopen loader make sure you have current and correct bin for a 2700 then make all connections tigthlly to box and comp if your useing usb adapter your gonna need to configure your com port to use for it
Nothing works. I tried everything switching the box off nad even got a new null modem cable. When I try to download loader just stay at 0% and does not do anything. It is as if receiver box is not connected to computer. Please provide some real help
Thanks guys for the reply. I had to rest teh box to factory setting and then load the bin 279. It is working now. By the way does naybody know how to get indian channgels. I am using dish500, but do not have 118.7 lNB
