Silver Member Username: Kenny_hammondPost Number: 291 Registered: Jan-05 | I just went and baught some kicker comps that someone on here recomended over jl audio and they suck! I have 2 12s in a sealed box with a 1200w amp with a crossover and they suck!!! I am going to buy some jl audio or rockford p1 (have a small box (extended cab truck)) |
Gold Member Username: JoebruceTC Sounds/DLS Post Number: 2190 Registered: May-04 | What amp do you have? Are you sure they are hooked up right? All the settings on HU and amp right? |
Gold Member Username: RedlinerWilmington, Ma Post Number: 4462 Registered: Jun-05 | u sure u have them setup right. cause those subs tend to actually sound pretty decent and get loud. car audio is 10% equipment 90% install |
Gold Member Username: BernymacCambodia Post Number: 4082 Registered: Sep-04 | So what kind of "1200w amp" do you have? Is this the kicker comp or compvr? |
Gold Member Username: Nd4spd18Northwest PA Post Number: 7840 Registered: Jul-06 | Yea, comps are pretty weak.... so are p1s. |
Gold Member Username: Surferdude9371Im BTL Bumpin Post Number: 1061 Registered: Mar-07 | y didnt you port them? |
Gold Member Username: Surferdude9371Im BTL Bumpin Post Number: 1062 Registered: Mar-07 | i have an ext cab ranger and have an 8cuft ported box that is below the window so im sure you can have a ported box too |
Bronze Member Username: Basshead4lifeIowa Post Number: 17 Registered: Jun-08 | it's all in the install or you were pushin your amp to hard. |
Silver Member Username: Hittin1Lake Charles, La. United States Post Number: 529 Registered: May-07 | are the comp's or comp vr's... BIG DIFFERENCE! |
Gold Member Username: 04redmach1Columbus, GA USA Post Number: 2114 Registered: Mar-06 | Yea, we need more info. Comp or comp ver? What 1200 watt amp ya got? Kevin |
Bronze Member Username: Evildoughboy08Toledo, OH US and A Post Number: 64 Registered: Jun-08 | haha was it the conversation i had goin about JL W0s or kicker comps? i got 4 W0s and i was thinkin about upping to 4 comps, but some say yay, some say nay, so I just stayed with JL |
Silver Member Username: BoomtankRochester, NY USA Post Number: 586 Registered: Oct-06 | I've had a vast range of kicker comps and they have all been reasonably loud on low wrms. like 2 10's on a Ma Audio hk400d in a dodge intrepid trunk and they bumped fine. |
Silver Member Username: Kenny_hammondPost Number: 292 Registered: Jan-05 | its a profile amp and i have the box under my seat...so space is a big factor.... and they are just comps dont get me wron they sound good on low notes but they sort of distort or bottom out when u crank it up the amp is down alot and the output on the crossover is midways i have the crossover set around 80 and the bass boost is midways.... |
Bronze Member Username: Basshead4lifeIowa Post Number: 18 Registered: Jun-08 | turn your bass boost all the way down, your subs will sound cleaner. |
Silver Member Username: Kenny_hammondPost Number: 293 Registered: Jan-05 | when i do that they dont hit realy at all ??? |
Diamond Member Username: BestmankindPost Number: 21568 Registered: Oct-05 | check your gain. it might be set too low. bass boost sux. |
Gold Member Username: The_image_dynamicSan Diego, California Post Number: 4201 Registered: Dec-06 | Keeeeeeeeeeeeker! |
Silver Member Username: Hittin1Lake Charles, La. United States Post Number: 536 Registered: May-07 | u talking about the single V.C. Kicker comp?... that is scraping the bottom of the barrel. should have at least got the comp VR's... they are a decent , low budget sub.. |
Gold Member Username: Th3pwn3rI compensate... Post Number: 8304 Registered: Jul-06 | You get what you pay for. Well, not always. |
Bronze Member Username: Basshead4lifeIowa Post Number: 19 Registered: Jun-08 | since u turned off bass boost you'll have to raise ur gain a bit more, they will hit then. |
Gold Member Username: Safe_crackerChicago, IL US Post Number: 4658 Registered: Jan-06 | Every brand he squawked off SUCKS B@LLS!!!!... pOLO. |
Gold Member Username: The_image_dynamicSan Diego, California Post Number: 4217 Registered: Dec-06 | And Polo knows a thing or two about sucking balls. |
Silver Member Username: VisitorMiddleofnowhere, Minnesota USA Post Number: 188 Registered: Jul-07 | "Yea, we need more info. Comp or comp ver? What 1200 watt amp ya got? Kevin" its the super special "ill kill anyone from ssa" comp. that help at all fukwad? |
Gold Member Username: Safe_crackerChicago, IL US Post Number: 4661 Registered: Jan-06 | HEY BRAD vvvv |
Silver Member Username: Kenny_hammondPost Number: 294 Registered: Jan-05 | ok well i have turned all the bass down and they sound ok i think i am going to just go with cerwin vega or jl for my next option |
Silver Member Username: Hittin1Lake Charles, La. United States Post Number: 677 Registered: May-07 | just regular kicker comps on 1200 watts!?! WTF? they are a 150 wrms sub. I bet it did sound better when you cut back the "bass". Sayin "Fu(k Kicker" after you made a bad sub/amp pairing is kinda fu(ked up.. JMHO |
Bronze Member Username: Basshead4lifeIowa Post Number: 20 Registered: Jun-08 | lol they must have been overpowered by a lot, glad u got the bass soundin better again, upgrade ur subs that can handle what ur amp can put out and this won't happen to you |
Silver Member Username: B3n07Louisville, Ky USA Post Number: 940 Registered: Jul-07 | yeah budy dont say fck kicker because you screwed up thats your problem all kickers sound best if in ported box my opion but the comps blow any ways thats you problem for buying th buy one get one free subs of the year for 50 bucks |
Bronze Member Username: Basshead4lifeIowa Post Number: 21 Registered: Jun-08 | i agree with kicker subs meant for ported boxes. plus you got the kicker comps and they the entry level of that brand. |
