I have a pansat 2500a converted to 2700 and using puff bin, every thing works perfect but after a while the receiver restart by itself and doesn't stop doing it.. any suggestion? how can I fix it? pls....
Default PUFF PUFF PUFF PUFF Please help I have same problem with my Pansat 3000(clone) converted to PUFF it keeps rolling and rollling after I loaded 278 bin I tried re loading old bins 254,262,272..but it still no luck keeps rolling...
kacha you have to enter de keys manually, I put the tronic bin my receiver work for a few minutes and then goes black out and restart its being doing this for a while i think is trying to tell me to let it go, what do you think Nalin...
Hi Nalin I tried to put like you said bin 276 Tronic and F wannk 276 but stll the same keeps rolling I even tried to re convert to PUFF by loadind BOOT 60 and 253 bin but still rolling PUFF PUFF PUFF Maybe I did smt wrong..? Do I have to load factory bin before of BOOT 60..?
I think your problem is in the setup. User setup - and letting the keys in or manually entering the current keys.
You DO NOT LOAD factory bin. You have to use 2700 to 2500 conversion.exe file to do the revert to b60. You must not forget to install 294T before starting the new conversion process.
'PUFF links' for full kit 276 and files http://www.savefile.com/projects/808662067
'b75' Links for full kit 276 and files '" also for 'Revert to 2500' http://www.savefile.com/projects/808662079
Read the instructions properly in the section you have chosen. PLEASE DO NOT ATTEMPT WITHOUT READING INSTRUCTIONS.
I have Fortec Star. It was converted to Pansat 2500. I have tried a lot to load the bin. I have used BL V1.4 and GT Rom Loader. BL loader keeps saying "downloading 0%" and after a while says "write failed". GT Rom loader says "File type error", although the files are of BIN type. Please help me. If you want to suggest a loader and a bin file, please post the exact link so that I can get them easily.
Irrespective of the origin of your receiver, once converted, always use the BL updater 1.4 ALL 2500 and flu and other converted units use F/F db9 straight RS232 cable", so check your cable and make sure it is what it is supposed to be. If you are not sure, the best thing to buy is a M/F null adaptor, which basically gives you two alternatives - one with only the unknown cable and the other with both adaptor and cable.
If you totally fail, you will always suceed in revert to 2500 if you have the right cable and use the special 2700 to 2500 Loader Converter.exe and b60_boot.bin then you can decide to install either PUF or b75 after appropriate conversion again. 'PUFF links' for full kit 276 and files http://www.savefile.com/projects/808662067
Thanks for such a detailed message. I think partly the problem was with the cable. I was using a F/F RS 232 cable, but I changed it with a better quality one. By the way the old cable was fine with Pansat 2700A original. So, I changed the cable, used BL updater 1.4 and loaded bin file "fwank7_Jvvh-Team-PUFF_276" the loading process started. I am glad I was able to upload the file. I will be able to check it tomorrow if the receiver is working.
Kindly suggest me if I need to upload a different bin file.
