Witch switch to use, to connect one LNB to 2 receivers?
Username: Dafidof
Post Number: 74
I have a viewsat ultra and a BEV original receiver, I need to know witch kind of switch to use to have both of them working without loosing any channel.
thank you
Username: Satopia
Post Number: 203
dp34 switch
Username: Dafidof
Post Number: 75
are there something less expensive, like a simple splitter 950-2150MHZ???
Username: Justforhahas
Post Number: 18
The switch , if any needed, is determined by the LNB's on the dish, and the dish type, along with which model Bev receiver from DN. A simple A/B switch may be all you need.
DP switches are ONLY used for some Dish Pro LNB's and DN receivers.
Username: Dafidof
Post Number: 76
I've try a splitter 950-2150MHZ, but I got only horizontal channels, but all verticals are black (no signal). Are there some one whou can explain how this thing works. thank you
Username: Satopia
Post Number: 204
nope they can be used for single lbn set up also
