ok so two wires come from each lnb (110,119), so that takes up the ports and i need another 2 ports for the 61.5 lnb, can i just attach one wire from each lnb? Or do i need to buy a combiner/
If you have room to add an extra LNB all you need is a (diseq) swtich where all lnb's are connected and 1 wire to the STB, that is if your dish is big enough to capture the 3 signals (elliptical?)
If your present dish setup doesn't allow you to add an extra lnb, you need another dish
you need a diseqc switch,which has inputs for up to 4 satellites and output for 1 receiver you will hook up 119 to port 1,110 to port 2 and 61.5 on port 3 and likewise assign the same ports in your antenna settings on the receiver
