Username: Rated08 Post Number: 35 Registered: Nov-06
Saturday, July 12, 2008 - 18:28 GMT I put the latest bin Dbpsw-080710p and nothing. I have a viewsat platinum.It just keeps on saying searching signal.. quality bar's 0. So should i go and manually fix the dish from the roof?
Username: Cartier1 Post Number: 1926 Registered: Feb-07
Saturday, July 12, 2008 - 20:33 GMT NO CHECK YOUR CONFIGURATION MAKE SURE U GOT IT RIGHT AND DO A HARD BOOT FROM THE BACK AND LET IT ROLL IT WILL WORK .
Username: George_affolter RICHMOND,
CA
US
Post Number: 1 Registered: Nov-07
Sunday, July 13, 2008 - 02:55 GMT I HAVE SAME PROBLEM HOW DO I DO HARD BOOT
Username: Cartier1 Post Number: 1928 Registered: Feb-07
Sunday, July 13, 2008 - 03:09 GMT READ TURN OF THE UNIT FROM THE BACK
CA
US
Post Number: 2 Registered: Nov-07
Sunday, July 13, 2008 - 03:58 GMT COULD YOU EXPLANE A LITTLE BETTER PLEASE
Username: Doreenakadj Ontario
Post Number: 1722 Registered: Dec-06
Sunday, July 13, 2008 - 11:21 GMT George... There is a switch on the back of the receiver, turn it off then back on. That is how you "hard boot". Johnny... Turn OFF power from the back of the receiver.... Try unplug and repluging the coax satellite cable back in and turn the power back ON again.
