Kicker and hifonics.. how will this be?
Username: Deadrabit
Post Number: 552
my freind is looking at buying this amp and 4 kicker subs like this.
no idea how to wire it..
its single voice coil and the amp ... idk. haha
http://cgi.ebay.com/NEW-HIFONICS-ZEUS-600-WATT-2-CHANNEL-CAR-AMPLIFIER-AMP_W0QQi temZ300237365404QQihZ020QQcategoryZ39732QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
http://cgi.ebay.com/BRAND-NEW-10-KICKER-COMP-C10-SUB-4-OHM-300-W-C104_W0QQitemZ1 80259908948QQihZ008QQcategoryZ3291QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
its for a truck so its going behind his seats. not a lot of room
Username: Insearchofbass
Post Number: 9845
what kind of truck is it an extended cab (it must be installing four 10's) are you sure you have room to fit four tens without angling them....also im not fond of the idea of hifonics amps and the kicker comps I wouldnt get either
Username: Hurricanebr1an
Western Burbs of Chicago, IL Usa
Post Number: 573
Not a lot of room but he's putting in 4 10s?
Four svc4s can be wired to 1 ohm or 4 ohms.
Username: Nd4spd18
Northwest PA
Post Number: 7877
All around crap...... comps are decent quality but weak subs.
And that line of hifonics amps is crap.
Username: Hittin1
Lake Charles, La. United States
Post Number: 579
well when I read the title of this thread and noticed that M.S. was the last to post, I thought I wouyld have to possibly6 stand up for the kicker and hifonics setup...... That is until I read the entire thread.....
The Zeus...... not good..
Kicker comps... just as bad..
what is your budget?
what kind of truck?
what kind of sound are you wanting?
c'mon BLK.. I have faith that you probably knew the answer b4 u posted this thread... JMHO
Username: Neptune07
Grand Junction/Golden, CO
Post Number: 45
if you're going hifonics go brutus. or find something with more quality for the same price
Username: Ridinspinnas
Windsor, Ontario Canada
Post Number: 286
i would go with the brutus 1600
Username: Rovin
1 15 = 149.5 DBsTrinidad & T...
Post Number: 13997
my advice : buy 4 10s dual 2ohms CVR & a Hif brutus 2000d & that would be a sweet set ...make sure u have room to port ...
