turn receiver off and unhook co ax cable now turn receiver on and load latest file using a usb stick then turn receiver off hook up co ax cable and turn receiver on and wait for picture to come up
followed post again, but used the second to last bin, now it dosen't keep booting over and over, then installed a fresh copy of the pftausw-080710u, then it does the reboot over and over again, any one have a hammer I can borrow?
you have a problem with the cable, vs ultra is very sensitive to bad or loose connectors,also which kind of switch are you using? check all connectors and make sure they are not shorting and are tight post results
disconected everything, turned upsidedown to look for a reset button, didn't see anything, reconected everything except lnb cable, turned on, booted up searching signal, turned off, hooked up lnb cable, now its worked for 1 minuite so far!, guess turnung upsidedown is the possible fix!
