Help! with my VS Platinum
Username: Rated08
Post Number: 35
I put the latest bin Dbpsw-080710p and nothing. I have a viewsat platinum.It just keeps on saying searching signal.. quality bar's 0. So should i go and manually fix the dish from the roof?
Username: Cartier1
Post Number: 1926
NO CHECK YOUR CONFIGURATION MAKE SURE U GOT IT RIGHT AND DO A HARD BOOT FROM THE BACK AND LET IT ROLL IT WILL WORK .
Username: George_affolter
RICHMOND, CA US
I HAVE SAME PROBLEM HOW DO I DO HARD BOOT
Username: Cartier1
Post Number: 1928
READ TURN OF THE UNIT FROM THE BACK
RICHMOND, CA US
COULD YOU EXPLANE A LITTLE BETTER PLEASE
Username: Doreenakadj
Ontario Canada
Post Number: 1722
George... There is a switch on the back of the receiver, turn it off then back on. That is how you "hard boot".
Johnny... Turn OFF power from the back of the receiver.... Try unplug and repluging the coax satellite cable back in and turn the power back ON again.
