Gold Member Username: Volfenhagking1600
SSD Wangin,
Shawano, Wis...
Post Number: 1258 Registered: Oct-06
Posted on How would i hook up my orion 2500d to my dual 1 ohm btl at 2 ohms thanks |
Silver Member Username: Hittin1
Lake Charles,
La.
United States
Post Number: 642 Registered: May-07
Posted on  |
SSD Wangin,
Shawano, Wis...
Post Number: 1259 Registered: Oct-06
Posted on i know that.. but on my amp theres 2 positive and 2 negative.. do i just do one positive on one channel and negative on the other channel? |
Gold Member Username: Nd4spd18
Northwest PA
Post Number: 7910 Registered: Jul-06
Posted on There is only ONE CHANNEL....... Ugh I swear it's like 90% of people in care audio cannot understand this amazingly simple concept. Just use one set of terminals. |
Diamond Member Username: Bestmankind
Post Number: 21734 Registered: Oct-05
Posted on the 2 positives and 2 negatives are connected internally. so it don't matter which set you use. |
Bronze Member Username: Beamerboy46350
LaPorte,
IN
United States
Post Number: 56 Registered: Jun-08
Posted on The second set is if you had dual 2 ohms at 1 ohm you wouldant have to do any splicing !! |
