I have a Pansat 3500 S/D. It worked fine. I have a twin dish pro plus 500 lnb and a twin dish pro 500 lnb. Each worked fine with Pansat 3500 SD and 110 and 119.
Well, I added a Skywalker 1 to the equation. So, I decided to use the two dishes together. I was going to use the Dish Pro to get 129 and feed that into the input of the Dish Pro Plus 500 which would be set up to get 110 and 119 while dish 500 got 129 for me for HD.
Well I managed to get somewhat of a signal and a few TPs on Dish 500...enough to test. So I output the Dish 500 into the Dish Pro Plus 500 input and then ran the output from the twin dish pro plus 500s to the 3500 S D and to the skywalker.
I was using the SD to test for signal. Well...when I ran the configuration above, the level drops to 30 % on all LNBS and TPs. Why is this? Do I not have enough power? Am I doing something wrong? Will this set up even work? Please adivse if possible. Thank you.
