Gold Member Username: Arande2Rattle your ... Missouri Post Number: 2858 Registered: Dec-06 | Hey I've been away from car audio and I've forgotten a lot. If someone can remind me of some of the SQ brands and such it'd me nice. All I remember is McIntosh, Zapco, CDT, Focal, and maybe Fi. Thanks. |
Gold Member Username: JakeyplaysbassSt. Louis, MO / ASU Post Number: 3100 Registered: Jul-05 | Amps, subs, speakers? Theres alot. |
Gold Member Username: Arande2Rattle your ... Missouri Post Number: 2859 Registered: Dec-06 | Eh probably speakers and head units since that would be the first thing to upgrade. |
Gold Member Username: Arande2Rattle your ... Missouri Post Number: 2860 Registered: Dec-06 | http://www.cdtaudio.com/6x9_series_08.htm I was looking at the woofer since it would be an easy replacement and should get rid of the annoying upper frequencies that draw attention to the back of the vehicle. Being elliptical, its resonant properties aren't optimal. I know that. If it's not too hard to put a 6.5" in instead, convince me that it's not hard. |
Gold Member Username: Arande2Rattle your ... Missouri Post Number: 2861 Registered: Dec-06 | It seems all the prices of everything is way too high it looks like I'll have to give it some time because it's either quality or nothing. At least semi-quality.. Things also have to get loud sometimes because my sister's like "Yeaah!" and turns up the volume until it's badly distorting. |
Gold Member Username: FrkkevinTeam DLSSuperNatural... Post Number: 5299 Registered: Nov-05 | light on a budget but quality, look into jbl |
Silver Member Username: GibsonguyStorrs, CT USA Post Number: 274 Registered: May-08 | How can you even mention FI with those other brands in terms of sq? FI and those companies are completely different. |
Gold Member Username: JakeyplaysbassSt. Louis, MO / ASU Post Number: 3104 Registered: Jul-05 | HU-Clarion DRZ9255 Front stage speakers- Dynaudio Esotec 362, Hertz MLK3, Morel Supremo 5 with an Elate 9". Front stage amp- McIntosh MCC602TM Substage- (2) Hertz Mille 2500, (2) IDmax 10s, (2) DD 9110s Sub amps- (2) Zapco c2k 6.0, (2) DLS A6, (2) PPI art A1200 Any of those combos would be absolutely killer for an SQ setup. |
Platinum Member Username: WingmanaliveA pic is worth 1000 posts!! Post Number: 17448 Registered: Jun-06 | Get your IB up and running yet Andre? |
Silver Member Username: GibsonguyStorrs, CT USA Post Number: 275 Registered: May-08 | jake papa had some good advice. all that equipment will get the job done. |
Gold Member Username: JakeyplaysbassSt. Louis, MO / ASU Post Number: 3106 Registered: Jul-05 | Thanks gib, just my little dream systems. |
Gold Member Username: Arande2Rattle your ... Missouri Post Number: 2862 Registered: Dec-06 | No, Paul. I don't have any money! Plus it'll be LLT to get more output. Speaking of money, those are what I was looking at before I forgot about them. The only problem here is I'll never afford something of that..umm..well you know. Plus I feel safer spending money on equipment in my house than equipment in a car. |
Platinum Member Username: WingmanaliveA pic is worth 1000 posts!! Post Number: 17453 Registered: Jun-06 | I concur young sir. Mobile audio is just that at times, mobile lol. Glad to see you're still around. |
Platinum Member Username: Nyyfan1315 Mag USA Post Number: 10026 Registered: Jul-06 | Hybrid Audio Technology anyone? |
Gold Member Username: Th3pwn3rI compensate... Post Number: 8340 Registered: Jul-06 | Morel, Seas, Rainbow, DLS. |
Gold Member Username: Arande2Rattle your ... Missouri Post Number: 2864 Registered: Dec-06 | Thanks guys. Since I won't have a car for a while, this is really just research into audio components overall (from pro to home to car audio) |
