Port question
Username: Turnmat
Racine, Wi
Post Number: 761
The box that i am building is 1.5 cu ft and i wanted to do 2 slot ports. The port needs to be 99.25 inches long. So my question is do both ports need to be 99.25 or do i divide the port length by 2 for each port?
Username: Trueaudiophile
how much port area for each port are we talking about here? also what did you want to tune it to?
Username: Turnmat
Racine, Wi
Post Number: 762
The port that i had calculated was 10 tall x 3 wide. The tuning is 32 hz. I was using http://www.carstereo.com/help2/Articles.cfm?id=31
thats 2 30sq inches of port for a 1.5cuft box. way too much port. and yes the 99inches is for each port. you want to reduce the port area and also just do one port.
Username: Extrmndor3
Http://illuzonemu.serv..., ^^^Sick Game
Post Number: 7962
excuse me pedophile
Username: Turnmat
Racine, Wi
Post Number: 763
why over on ssa do they recommend such a long port? see following link http://www.soundsolutionsaudio.com/forum/index.php?showtopic=10775
The one guy said he was in the realm of 100" long
Post Number: 7963
girls says the longer the better..
but i size the wider then better ;)
Username: Turnmat
Racine, Wi
Post Number: 764
lol. got to have both then your in for sure :-)
