New member Username: Stickyfingers11Colac, Victoria Australia Post Number: 1 Registered: Jul-08 | I have 2x kicker S12L5 4 ohm version solobaric subs. i want to build the Maxium vented enclosure for the speaker: 3.25cbft/92L. The thing i dont know would be the correct or best port size for the box because i dont know what frequecy i want the port to be, if someone has had got or had same subs with similar enclosure size could u let me know the dimensions i need to get them in me car for some entertainment :D |
Silver Member Username: Hittin1Lake Charles, La. United States Post Number: 618 Registered: May-07 | 3.25 ft3 (92L) + port displacement 3 x 13.25" (7.6x34cm) port, 14.5" (37cm) long Power Handling = 600W RMS |
New member Username: Stickyfingers11Colac, Victoria Australia Post Number: 2 Registered: Jul-08 | yes but i want the dimensions for the box as well.. what frequency is that port tuned too? and im running the subs on 500wrms each not 600wrms |
Platinum Member Username: Rovin1 15 = 149.1DBsTrinidad & T... Post Number: 13990 Registered: Jul-05 | kicker rec specs actually work decent so u can use it & that box dimensions calculator on http://www.reaudio.com/speaker_box/LPort_Box_Calc.html ... |
Silver Member Username: Hittin1Lake Charles, La. United States Post Number: 619 Registered: May-07 | well I know that it's a prefab, BUT it is a well built tank of a box.... IO used it and was pleased... I had 2 L5 12's on a memphis pr1000d and hit a 142.5 on termlab... http://www.proboxrocks.com/products/enclosures/unloaded/superbass/212SQSPB/index .shtml |
