New member Username: Nina_josephidesPost Number: 1 Registered: Jul-08 | There is no sound while the radio is open and even though there is a mute button I don't know how it works |
Gold Member Username: The_image_dynamicSan Diego, California Post Number: 4256 Registered: Dec-06 | Which radio? |
New member Username: Nina_josephidesPost Number: 2 Registered: Jul-08 | mercedes-benz audio 10 |
Gold Member Username: The_image_dynamicSan Diego, California Post Number: 4258 Registered: Dec-06 | That model is made by Alpine and the model number is MF2910. The mute button is located at the bottom left hand side of the center display as indicated in the picture below. Below that is a screenshot of page 15 of the users manual that shows how to operate the mute function. At bottom is a link to the complete users manual in pdf. http://www.perfectmarketaudio.com/Audio_10%20Manual%20PDF.pdf |
New member Username: Nina_josephidesPost Number: 3 Registered: Jul-08 | thank you for the info. I tried pressing the button but it didn't work. I must be doing something wrong...Don't know. Maybe someone pressed another button and caused this. |
Silver Member Username: ExigeCDT, Audiopulse Dealer Post Number: 481 Registered: Nov-07 | damn Brad where do you find this stuff |
