Question for Nalin
Username: Rags
Post Number: 22
Message for Nalin -
Nalin> I am on the fwank7_Jvvh-PUFF_275 bin since July 3rd - and have not switched on the TV for the last few days.
I dont see a new update on the public.box site - is there something I am missing.
When I updated the software on July 3rd - it was working fine.
Can you please advise.
Thanks bro!
Username: Nydas
Post Number: 11084
Latest BIN for Pansat 2700, clones and conversion 2500/2700 is version 275
There are several puff versions and one LZMA and 1-2 b75 version for converted receivers.
As far as I can see they are posted at the Box.net site.
Saif and Tronics b75 bins are missing. You can get these at
[link removed]
Username: Rags
Post Number: 23
here is what happened.
I upgraded to b75 and then went on to puff. On puff i have done baout 4-5 version upgrades and it was working fine.
Even with the latest upgrade to 275, things were fine except the last 3-4 days.
Do you suggest i reinstall the fwank7_Jvvh-PUFF_275 upgrade?
Please advise.
thanks
Username: Thermongod
Post :579
Post Number: 13
Message for Nalin -
Thanks bro!
Username: Mcrabbycabby
Wpg, Man Canada
Post Number: 60
hello i have a 2700 clone i put the 275 v1 tivo bin and i got wierd diseq things with this bin its not the normal 1 i ussally get it has lots of choises which 1 will work best i hope you know what im talking about thank you.
Username: Nydas
Post Number: 11086
raghuveer yadav: Install another Puff_275 BIN and if it gives problems, it would be best for you to install the b60 BOOT ad 294T BIN and start the process of conversion again.
Username: Nydas
Post Number: 11087
DisEqC choices are usually 1,2,3, and 4. Your choice depends upon what physical connection you have to the switch. Most installations have 119W on Port 1, 110W on port 2 and some other (such as 61.5 or 148W) on Port 3 or 4.
