System layout
Username: Crayola0
Portage, Wisconsin
Post Number: 2410
well im makin more money since im workin two jobs so a system is comin very soon. but i just think that the bass will over power my stock speakers. if i upgrade the speakers and amp them i wont be able to run as much power becasue of my alt. its stock 110 so how much power should i run to the subs and component amp?
Username: Th3pwn3r
I compensate...
Post Number: 8321
Why don't you just take it easy with the output of your substage until you upgrade your mid and high setup? That would be the smart thing to do.
