So confused
Username: Volfenhagking1600
SSD Wangin, Shawano, Wis... USA
Post Number: 1254
Which amp should i use to power my D1 BTL fully loaded?
Orion 2500D - $300
AQ2200D - $389
Thank you
jamie
Username: Goodie_goop
Mid town, Texas U.S.
Post Number: 924
where are you getting the orion for 300?
Username: Loudon
Post Number: 2525
u wouldnt hear the difference
Post Number: 1255
caraudio.com
Post Number: 926
good price on the orion then...but i would get the AQ for customer service and warrenty
Post Number: 1256
would i be good with a 200 amp alternator and a SPV70 in the back?
Username: Jkidder
Worlds gunna end, In 2012
Post Number: 3645
dual 1 can only be wired to .5 or 2 ohms. which of the amps you listed put out enough power at 2 ohms or are safe enough to run .5 daily? id rec. looking for a kx2500 or zx2500. you need the power at 2 ohms or .5 ohms...
the cisco kid
Username: Hdubb
Team Revolution
Post Number: 3812
good call jk
Username: Deadrabit
Post Number: 531
aq2200
Username: Nd4spd18
Northwest PA
Post Number: 7851
Pretty much a tie, those are both great amps but I would get new over used
Username: Ridinspinnas
Windsor, Ontario Canada
Post Number: 276
get a zx2500.1 i highly recommend that amp
Username: Nd4spd18
Northwest PA
Post Number: 7865
HOLD UP here, chris's post just made me realize..... if your BTL is dual 1 then the AQ and orion will both NOT work as they are 1 ohm.
Your sub wires to 2 ohms so yeah the ZX2500.1 is probably your best bet.
Post Number: 1257
orion will do about 2000 at 2 ohms
Username: Nd4spd18
Northwest PA
Post Number: 7871
Loaded BTL would be better with the 2500+ from the kicker
Username: Rovin
Post Number: 13981
some of answered without noticing he said DUAL 1
kicker 2500 should be gr8 ...
