Todays install project
Username: Nd4spd18
Northwest PA
Post Number: 7900
Sirius satellite radio in-car tuner and HU interface
Comes with the tuner and adapter module to interface with the JVC HU. Everythings controlled and displayed on the HU no goofy tuners on the dash.
Did the install after work today I just finished. The tuner is mounted in the center console since there's no space at all in the dash.
Pretty easy install, just ran bus cable to HU and tapped constant power wire for the tuner.
And there it is, sirius radio
I'm not thrilled about the sound quality I can hear the compression but I knew that would be the case with sat radio. But having all these channels is way cool.
Diamond Member
Post Number: 21705
nice. now you can listen to howard stern.
oh and controlling the satellite radio from the hu ftw. can't stand those little controllers people install in their car.
where did you put the antenna? on the roof of your car or somewhere inside?
Username: Nd4spd18
Northwest PA
Post Number: 7902
X2 I can't stand those either.
The antenna is on the roof, I routed it's really long wire inside to the tuner. The antenna is actually really small I was surprised.
Diamond Member
Post Number: 21707
also the magnet on that antenna is strong lol.
Diamond Member
Post Number: 21708
i am so tempted to get sirius too. i already have xm though.
