Wedge at end of port to increase port velocity
Username: Howtoeatapencil
Post Number: 170
The friend thats helping me build my box reccomended i put little wedges at the end of the port, so at the opening it has less surface area and will have more velocity.
What would putting wedges at the end do?
<img>
something liekthat
Username: Insearchofbass
Post Number: 9572
you dont want more port velocity you want less and flaring like in the case of aero ports achieves that....you can flare a slot port also
Username: Van_man
Boston South, MA
Post Number: 4040
As sean stated, And stop having yur friend help you. He doesnt know jack.
google flaired port pics, and you will see they are the oppisite of that pic. Also kerfed ports work well too.
Post Number: 9575
yeah with a statement like your friend made it doesnt seem like he knows alot
Post Number: 171
dang he seems like he knows alot, would that just make it sound shitty? does it have ANy advantages?
Username: Imi4tth3w
San Antonio, Texas USA
Post Number: 173
if there was a curve in the port INSIDE the box i can see how that would work cause thats how my box is but as its going out? =/
Post Number: 9591
there is no good idea to this design at all ....take the previous advice and stop letting this person help you he doesnt seem to know anything if hes suggesting this
Username: Nd4spd18
Northwest PA
Post Number: 7732
Hahaha that guy is an idiot...... more port AREA is what you want
Username: Hdubb
Team Revolution
Post Number: 3772
rounding corners in boxes does help. though it doesn't create velocity it help keeps a good air flow in the box. 3in wide 45 degree pieces in each corner can help the box become a little louder.and also other degree angles in the box caan bring a box to life. but that's more hardcore spl intentions. your friend had the right mindset but a wrong explanation as to why it helps I think
Username: Hdubb
Team Revolution
Post Number: 3773
ehh I think I read post wrong he wants you to put it at the end of the port or port corner? no no and end of port lol
Username: Zacdavis
Beloit, Wi
Post Number: 1668
well sorry to say but all of you guys are wrong.
Velocity is in fact what you want.
Improving your port's velocity decreases resistance.
Air flow velocity is improved by flaring or rounding edges.
Username: Southernrebel
Monroe, Louisiana 2 DD3515s, 2...
Post Number: 6448
Um...I think this got alil twisted around.
Not 100% sure what angle you are looking at this from Zac, but...
By constricting port area, the port velocity will increase.
This smaller port will restrict the airflow...aka, more air resistance.
Now, don't get me wrong. Too big a port can be harmful to sound, but to small a port can also.
For instance, another local shop here in town builds their ports FAR too small. I saw them sell a RF T2 12" in a ~2.25cuft box w/ a 3.75"x3.75" port. W/ about 800wrms that port sounded like a dam whistle.
Post Number: 9593
yeah this guys design will cause resistance not proper air flow
Username: Zacdavis
Beloit, Wi
Post Number: 1670
The design pictured is of course wrong haha.
The "velocity" portion of the thread thats being discussed is confusing.
I think your speaking of an increase in velocity pressure?
Increasing the air velocity without increasing resistance is what we're after, which is why we use flared port ends, to improve the air's velocity.
Usable velocity, increasing it is what you want.
Username: Van_man
Boston South, MA
Post Number: 4056
so which port would achive higher volocity? port 1 or 2?
A pic is worth 1000 posts!!
Post Number: 17098
Simple physics point to # 1.
Higher velocity = port noise.
Post Number: 172
so just leave the port as a normal port?
Username: Explictx
Glen Burnie, Maryland USA
Post Number: 635
Yeah i would just leave it alone you'll be fine. you can round the edges like said before but you'll be fine with out it. unless your going to all out SPL competing.
Username: Yukhui
4 15 AA Havocs, Memphis 4kw!!
Post Number: 939
"dang he seems like he knows alot, would that just make it sound shitty? does it have ANy advantages?"
Yeah
...If you like the sound of being in a wind tunnel
Username: Tdeaton1021
Near Tampa, Florida USA
Post Number: 4476
you guys are getting twisted up between velocity and turbulance. port 2 will have higher velocity and less chance of port noise. you want to achieve maximum velocity and minimal resistance and turbulance. having wedges at the end of the port simulating a flared port CAN help your spl and minimize resistance.
I don't know who his friend is and if he's said soemthign dumb in the past but he is right with this....
Username: Van_man
Boston South, MA
Post Number: 4075
so pic 2 would be a better spl burp box design?
Post Number: 9600
his friend is saying port 1 is going to improve the port over a standard one but im/we are saying it wont....he didnt mention port 2 according to earl's post but port 2 is being used an example of how a port would work better
Username: Van_man
Boston South, MA
Post Number: 4084
this thread has become very confusing.
so to recap.
port 1 good or no good for spl.
port 2 good or no good for spl.
Post Number: 9601
anyway its simple port 2 is better than a standard round port and port 1 is a bad idea
Username: Silvermopar
Nebraska
Post Number: 98
I agree with sean. lol
Post Number: 17108
This thread HAS gotten out of context IMO.
Think of it like a funnel. Blow in one end and get a certain velocity out the other. Reverse it and get an entirely different result.
Anything causing "turbulence" decreases/disrupts airflow.
Airflow(ported designs)=bass.
No?
Username: Phil_salisbury
Post Number: 717
WTF, higher velocity of air movement does not translate in improved SPL performance.
All Port 1 does is restrict the flow of air which results in back pressure buildup within the port which restricts and more to the point reduces the movement of the cone of the subwoofer.
So, that being the case, anyone that thinks port 1 will improve your spl numbers is fuking idiot.
Username: Zacdavis
Beloit, Wi
Post Number: 1671
#1 Everybody here agrees pic 1 is retarded.
#2 Usable velocity WILL improve your spl performance, call me a fuking idiot all you want.
#3 Flared ports will increase usable velocity, decrease resistance, decrease port noise, and improve spl performance.
I'm not going to debate this any more haha, its just a fact.
The only person on the same page with me here is Trevor. Somehow we're failing to word this properly I guess?...
Post Number: 718
OK Zac, if you port is such an " amazing " spl improvement, then I guess we'll be seeing it on all the top spl competitors enclosures, when that day happens, you can talk all the smak ya want, till then.
Flared Ports vs that other mickey mouse horsesh!t port design is a completely different story and don't even try to think you actually got over on anyone here.
Username: Zacdavis
Beloit, Wi
Post Number: 1672
Uhh, well i use them, and I think i have a loud system.
and hey?, who the hell are you anyways?
Post Number: 719
You " think " you have loud system. He!!, I can find a number of people that " think " their systems are " LOUD " and they maybe right, but, saying your "LOUD" and proving it is two different things.
How " loud " are you ??? 150+, if so, good for you.
Username: Naledge503
LowDownForum.com
Post Number: 3930
lol. I believe he did 160.0 in USACi pro stock 0-1000.
Zac did you forget about me bro:-)?
Username: Tatonka
-[Team Audible Insanity]-
Post Number: 1856
Wow, all this trash talking is making Phil look very unprofessional.
And yes, Zac Davis is extremely known in USACI with multiple world championships.
Post Number: 9603
Zac Davis...."#1 Everybody here agrees pic 1 is retarded.
The only person on the same page with me here is Trevor. Somehow we're failing to word this properly I guess?...'
Ive been following this all along Zac and so have the others
initially I think your comment here got things confused....
Zac Davis...."well sorry to say but all of you guys are wrong.
Air flow velocity is improved by flaring or rounding edges."
you were focusing on how a port should work with improved quality airflow and without resistance while we were all commenting on the the poor airflow causing resistance/turbulence from this guys port 1 design shared in the beginning of the thread with an image link....Trevor just came in and read the later posts and made his comments because he thought we didnt understand as well
Woodlawn Cabinetry - Philster...."WTF, higher velocity of air movement does not translate in improved SPL performance.
So, that being the case, anyone that thinks port 1 will improve your spl numbers is fuking idiot."
Phil's focus was on the poor design idea of port 1 and I think he got upset at the idea that anyone would believe that was a good idea and he proceeded to give his explanation why....I dont think he was calling you an idiot I think he was just calling the idea involved with port 1 and anyone believing it stupid....and we all know you wouldnt recommend port 1
Post Number: 720
Sean,
Exactly, my comments were towards the design of port 1 and the misinformation the OP was lead to believe.
I know full well the physic's of aero / flared ports and there effects and I know d@mn well that even when I used round ports I fabricate trim rings for the ends of the port and round them over to achieve ( to a degree ) the same dynamic's of aero/ flared ports.
I knew d@mn well I should of said nothing because there's always going to be someone that going to take it out of context and Zac did exactly just that.
Username: Zacdavis
Beloit, Wi
Post Number: 1673
I hear ya Sean.
Absolutely, pic 1 is a terrible idea.
Hmm?...I wonder if the initial person who gave this guy the idea in the first place was meaning for him to put 45 degree angles on the inside of the port at the bends...maybe he misinterpreted it from the get go.
But either way, we all agree 1 is a bad idea, no question there...my only deal is this whole velocity thing, and I'm sorry to say to this "woodlawn guy" that I'm right and he is wrong...he can talk all the smack he wants, telling me I need to prove myself, wow, I dont need to prove anything to anyone, I was just trying to be helpful.
It isnt very hard to do a search on flared ports to find that improving usable velocity decreases port noise and resistance.
This isnt entirely rocket science here, I can't believe something as simple as this has gone on this long.
Hey Woodlong Cabinet guy, you said.....
quoteOK Zac, if you port is such an " amazing " spl improvement, then I guess we'll be seeing it on all the top spl competitors enclosures, when that day happens, you can talk all the smak ya want, till then.
....uhh? till then?.....
quoteYou " think " you have loud system. He!!, I can find a number of people that " think " their systems are " LOUD " and they maybe right, but, saying your "LOUD" and proving it is two different things.
haha, ok. I don't normally bust out with a pat on my own back, I hate people who're full of themselves, but since YOU like to talk smack about how I need to prove myself before anything I say is viable...well, here ya go.
...Naledge, no, I havent forgotten about you. I have the measurements on paper I need to send them to you via email, will do tonight.
Post Number: 721
Zac,
Yeah, I know all about your accomplishments, good for you, your a man among many that more than likely have just as many.
WTF is your malfunction, don't not understand that I was talking about port design #1 or you just have hard time grasping reading comprehension.
Username: Zacdavis
Beloit, Wi
Post Number: 1674
Ahh, I see, you wanna be a smart azz, well read my previous posts. It clearly reads...I stated design 1 was a terrible idea. It was you who chimed in after that stating I had no idea what I was talking about, your the reader with the comprehension deficiency.
I don't know you but already don't like you. Your a smart azz and I'm half tempted to call your mediocre box building azz out. What the hell is YOUR malfunction?
Username: Safe_cracker
Chicago, IL US
Post Number: 4634
If you used a large enough port the flare gains would be minimal, you get more resistance with the port being inside the box lOl. From what I remember a single port closest to the dia of the subwoofer and still able to achieve a desired tune with a realistic length is the goal for maximum radiation of the back wave. Polo.
Post Number: 9606
Zac Davis...."Hmm?...I wonder if the initial person who gave this guy the idea in the first place was meaning for him to put 45 degree angles on the inside of the port at the bends...maybe he misinterpreted it from the get go."
I wondered if earl misunderstood his friend as well....I hope so
Post Number: 6456
Post Number: 4477
haha i never even say that picture in the first post until now. I thought it was a broken link so I didn't click it.
So to sum it ALL up
No, earl, do not do that idea in the picture. putting 45d wedges in port bends can help you (sometimes without them gains spl but with them helps a smoother response). and inversing those wedges in your picture to funnel air into the port rather than out of it is also a helpful idea.
Me and Zac were on the same confused page and were right in what we said but it was indirectly on topic.
I don't see what anyone is fighting about?
Post Number: 173
im gunna talk to the guy, maybe he meant do what was in picture 2
Username: Mike11202
RE MT 15 VFL 200.1 , Sewell, NJ US
Post Number: 1802
Post Number: 9610
"Me and Zac were on the same confused page and were right in what we said but it was indirectly on topic."
its cool bud....we all know this was a simple answer and as far as fighting between Zac and Phil im sure both of them can put it behind them because in my opinion it really did start because of a misunderstanding
earl...."im gunna talk to the guy, maybe he meant do what was in picture 2"
please do and let us know what he says
Username: Van_man
Boston South, MA
Post Number: 4091
great debate guys. What a fucked up thread.
Edit:
As sean stated, And stop having yur friend help you. He doesnt know Zac.
Username: Tatonka
Post Number: 1863
This is too good of a thread to be sent to the archives :-(
Username: Th3pwn3r
I compensate...
Post Number: 8306
Haha, I missed a good thread.
Post Number: 9764
it was a post with a simple answer but got a little confused for a while
