Feedback
Username: Purplehase_bong
BC Canada
Post Number: 271
my car is a 95 z28 camaro with the optional factory amp on teh speakers. as soon as i changed the factory deck i got feedback when its at low volume, not engine feedback but more like when ypu crank ur speakers when the deck isnt paying music ie mute. what can i do to eliminate the problem. i changed my deck 3 times now, always to a better one but still no luck.
Diamond Member
Post Number: 21569
have you tried turning down the gain on your amp?
Username: The_image_dynamic
San Diego, California
Post Number: 4205
Factory amps generally have no external gain control, if any. I would guess that the issue here is that the increase in output voltage from the HU is not sitting well with the factory amp and it is letting you know this.
BC Canada
Post Number: 272
ah, shitty. so i guess id have to reroute my wires eh, meh i guess ill have to live with it.
