Silver Member Username: Rtyauch301Post Number: 250 Registered: Aug-06 | ok so my car only has holes for 4X6's in the door so what will sound better 4X6 plate speakers or just regular 4X6's |
Silver Member Username: ExigeCDT, Audiopulse Dealer Post Number: 457 Registered: Nov-07 | Can you expand the holes to fit 6.5" speakers? Not too many companies make 4x6 speakers and those that do are not that great. |
Silver Member Username: Rtyauch301Post Number: 251 Registered: Aug-06 | no i cant expand it to a 6.5 theirs not enough room i have thought about putting it in the outside of the door were their is enough room but the factory grill is to long i think its 7" at the longest point so i was wondering if 6X8 would sound better because i would like a a component set |
Silver Member Username: ExigeCDT, Audiopulse Dealer Post Number: 459 Registered: Nov-07 | start with this: what's your budget for everything? from there we can figure out what will work best. |
Silver Member Username: Rtyauch301Post Number: 252 Registered: Aug-06 | the best i can do is $150 for a set of mid's |
Silver Member Username: Rtyauch301Post Number: 254 Registered: Aug-06 | nm i found this what is a good set of 6.5's for that price http://cgi.ebay.com/4x6-to-6-5-6-Speaker-Adapter-97-05-Malibu-Grand-Am_W0QQitemZ 310061982747QQihZ021QQcategoryZ14932QQssPageNameZWDVWQQrdZ1QQcmdZViewItem |
Silver Member Username: ExigeCDT, Audiopulse Dealer Post Number: 467 Registered: Nov-07 | Good find. Check your PM's. There's some good stuff there. |
