New member Username: Bbruno78Post Number: 1 Registered: Jun-08 | Have had this TV for a year and a half with no issues. Then a fwe weeks ago, started turning on and off randomly. They say they have a firmware upgrade that will fix it, but are trying to charge me for it - which is BS since it is a problem inherent to the TV. Also, just started randomly losing sound - sometimes for a few minutes sometimes for hours. Anyone had this issue or could shed some light? Thanks! |
Bronze Member Username: 66gtkcodeSan Francisco, California USA Post Number: 13 Registered: Mar-04 | Don't know if you've solved the problem yet, but I have the same TV with the same problem and this is what fixed it. Check the link below http://www.fixya.com/support/t413429-sharp_aquos_lc_26d4u_sound_problem |
