Kicker vs. phoenix gold.
Username: Talon_es93
Trinidad, Co
Post Number: 763
what would be better.. the PG octane-r or the kicker ds693.. they would be rearfills in a 4 door 97 accord powered off an a6004t...
Username: Joebruce
TC Sounds/DLS
Post Number: 2179
PG is ok stuff for the money but theres alot better out there. Never heard any Kicker speakers so I cant say on those. Whats your budget and what size speakers do you need?
Username: Denim
SoundSolutionsAudio.com, MD USA
Post Number: 745
Skip the rear fill and put the money towards your front stage or sound deadening.
Username: Nd4spd18
Northwest PA
Post Number: 7830
^^^^ X2
Trinidad, Co
Post Number: 765
i got the earthquakes fc6.2 in the front off an a6004t but i want more tweets... yesterday i picked up a free pair of alpine tweeters with crossovers that went to a type-r component set... anything i could do with that??? add in front or put em by my rearfill and leave it empty??
Trinidad, Co
Post Number: 766
would the sound change much if i put deadening on my doors??
Username: Denim
Post Number: 746
It will reduce vibration and some road noise. Always a big improvement.
Trinidad, Co
Post Number: 767
well i guess i will tke out the earthquakes... dynamat the doors... and put in a type-r component set i just got :D and i'll see if thats enough... if not i'll fill the back with the earthquakes
