12v fans
Username: Jakeyplaysbass
St. Louis, MO / ASU
Post Number: 2932
Hey has anyone used 12v fans to keep there amps cool? Im looking at some right now but really dont know what i should do... AIM-jakeyplaysbass26
Diamond Member
Post Number: 21488
are the pc fans 12v?
Username: The_mod
BANVILLEUSA
Post Number: 33
Yes, 12V fans work.
I used to install them w/ Rockford A-series amps. You just wire them to a relay using the remote.
A few other companies make fans. Stinger makes a thermostat also.
St. Louis, MO / ASU
Post Number: 2934
This site has pretty much every size to choose from...
http://www.buyextras.com/dc12vfans.html
Im thinking about using 2 2" to push the air and 2 2" to pull the air out. I need to draw up some pics tonight and then it should make sense.
Username: The_mod
BANVILLEUSA
Post Number: 35
A few of those fans set up to push and pull air would do great.
Just grab a relay and a switch for them, you will be fine.
If you need more air-flow, Stinger makes a high flow fan.
St. Louis, MO / ASU
Post Number: 2938
Heres what im thinking...
-The black rectangle "holes" will be covered with plexi and have the amps mounted to the car under.
-The right fans will push air while the left will pull.
-The frame (3/4mdf) will be in 2 pieces so i can pull one up to get to the amps. The second piece will be under the box so everything is the same height.
St. Louis, MO / ASU
Post Number: 2941
This is going to be impossible to explain without a drawing... but... when wiring a set of fans should i...
Distro block to relay (87), HU to relay (86), ground to relay (87), fans to relay (30)...this is on the tyco relay (old bosch).
Diamond Member
Post Number: 21493
good idea jake.
Username: James1115
Use a simple...
Post Number: 10692
you got it covered man!
