Bronze Member Username: Cld_canadaPost Number: 17 Registered: Jul-06 | I am little confused..I have converted my 2500 clone pansat receiver to 2700 clone. Wondering which file should I be using ? Any of these following?? X87BL 080617 B75 272 api or CloneSafe-B75-272-TiVo Please help |
Silver Member Username: MuchoPost Number: 393 Registered: Dec-07 | canada X87BL 080617 B75 272 api |
Platinum Member Username: NydasPost Number: 10977 Registered: Jun-06 | Everything you need for 2500/Flu to 2700 conversion in one package. Instructions included, including instructions for conversion between the three different boots http://public.box.net/2500_full_kit and select appropriate section Read the instructions properly in the section you have chosen. PLEASE DO NOT ATTEMPT WITHOUT READING INSTRUCTIONS. |
Platinum Member Username: NydasPost Number: 10978 Registered: Jun-06 | Canada: You DO NOT use genuine BL BINs, and you do not use clone-safe Tivo BINs. For 2500/flu to 2700 converted bixes, use only conversion BINs, either b-75 or PUFF or LZMA. Currently there are several 272 version for converted boxes from th ePUFF coders and one from b-75 coder. |
