Convince Me One Way
Username: Nyyfan13
15 Mag USA
Post Number: 9895
These are what it comes down to right now for me. Just these combos of amps.
1. Sundown SAE-1000 and a Sundown SAX 100.2
2. Audison LRX 1.400 and a Audison LRX 2.250
3. Mmats D1100.1 and a Mmats SQ2150
Obviously, the amps are about 1k for the sub and about 100-150 for the components.
I was set on the getting the Audison pair but after talking with some people and doing some thinking, I came to the conclusion that I would not be able to tell the difference between any of these amps. The only difference I would notice would be the weight of my wallet....if you catch my drift.
Am I wrong in this thinking?
Username: Gibsonguy
Storrs, CT USA
Post Number: 209
Go with the sundown and the 100.2. I bet you could even get it for $475 shipped if you knew where to buy from :-)
Diamond Member
Post Number: 21430
which ever you go with yanks, you have my full approval. hope that helped with your decision.
Username: Nyyfan13
15 Mag USA
Post Number: 9896
Lol. Your killing me Chad. After all we've been together, this is the answer I get from you lol.
I think I know the place Gibson ( ) and I plan on buying that from them when/if I go that route. Thanks for your input bud.
Username: Gibsonguy
Storrs, CT USA
Post Number: 210
np...gl making up your mind.
Username: Nd4spd18
Northwest PA
Post Number: 7781
Those are all very good amplifiers do I doubt you could tell a difference.
Username: Rovin
Post Number: 13937
all should be good
u can do sundown just to be different from almost every1 in ur area im sure .....
Username: 420alldaylong
Post Number: 3707
Sunup to Sundown is my choice.
Username: Naledge503
LowDownForum.com
Post Number: 3946
I pick Audison to be different:-)
Username: The_image_dynamic
San Diego, California
Post Number: 4165
Sundowns don't work during the day so go with Audison.
Username: Kingandsons07
Lincoln, NE TEAM RD U.S.A
Post Number: 1037
lol Brad
Username: Nyyfan13
15 Mag USA
Post Number: 9899
Lol Brad.
Jesse that is one of the main reasons I'm looking at Audison....just to have something not many other people have.
Sundown seems to be the favorite right now. My wallet likes that lol.
Diamond Member
Post Number: 21437
so what's the decision?
i would like to throw in the dls A3 and the A6 in your list.
Username: Insearchofbass
Post Number: 9641
sundown 1000.1
* 1000 x 1 watts @ 1 ohm
* 600 x 1 watts @ 2 ohms
* 300 x 1 watts @ 4 ohms
* 0.2v - 6v adjustable input sensitivity
* 10 Hz - 350 Hz Frequency Response
* > 90 dB S/N Ratio
* 4-Way Protection Circuit (Thermal, Overload, Speaker Short, and Over Current)
* Linkable to another SAZ-1000D for 1800 watts @ 2 ohms
* 35 Hz - 300 Hz adjustable 24dB Low-Pass Crossover
* 10 Hz - 60 Hz adjustable 24dB Subsonic Filter
* 0 - 180 degree adjustable phase shift
* 0 - 18 dB adjustable bass boost with 45 Hz center frequency
* Wired Remote Control unit included
* 3x 30 Amp Internal Fuses
* 4 AWG power and ground terminals **
* 11.5" L x 10.2" W x 2" H
* $399 US Dollars - MSRP
* $439 Canadian Dollars - MSRP
* $449 Euros - MSRP
* PRODUCT MANUAL
Audison LRx 1.400
LRx 1.400 is a mono amplifier especially designed to drive very low loads with thrilling energy reserve, built-in active filters and LRx typical compact size. Power supply and final stages use high current MOSFETs, which satisfy every power need. With its 900 watts at 1 Ohm, LRx 1.400 is the ideal amplifier to drive state-of-the-art subwoofers systems and to realise installations with very high SPL values and excellent timbre quality. It has a Hi-Pass stereo filter and a 24dB/Oct. Lo-Pass mono one; both are Butterworth, with independent adjustments. The subwoofer section has a bypass subsonic filter and a 24dB/Oct. slope one with Q factor adjustment and phase switch; thus, it always allows you to take full advantage of any speaker you are using.
* 1 Ohm Stable
* High Pass Crossover
* Low Pass Crossover
* 1 Pair RCA Outputs: Hi-Pass or Bypass
* RCA Input
* Subsonic Bypass
* Signal to Noise Ratio 105dB
* RMS Output 1 x 350 Watts @ 4 Ohms
* RMS Output 1 x 650 Watts @ 2 Ohms
* RMS Output 1 x 900 Watts @ 1 Ohm
* Dimensions: 370mm L x 176mm W x 56mm H
* Subsonic Filter
LRX-1.400 - Audison LRX1.400 1 Ch 900 Watt Amplifier with Crossover
D1100.1
# Frequency Response (-3db) 10 Hz to 230 Hz
# Signal to Noise Ratio -92db A weighted
# Distortion @ Rated Output < 0.1% THD+N
# Damping Factor @ 100 Hz > 125
# Input Sensitivity 150mV to 2.5Vrms
# Idle Current 1 amp
# Features
# Efficieancies over 90%
# 4 G Power Input Terminals
# Optimized for low impedance loads
# Twin MOSFET power supplies in larger models
# 24 dB/Octave Linkwitz-Riley infinitely variable crossovers
# "Flip-Top" heatsink for custom installs
DIMENSIONS ( L x W x H ) 7.375 x 11.5 x 2.125
i have to leave but it looks like a tough call even based on functions built in the amps
Username: Basssquared
Kansas
Post Number: 2173
i would go with Audison i mean yeah you may not be able to tell the difference but still its like having a stock corvette and a fixed up civic i mean maybe they both can do 10 second quarter miles but one of them is still a corvette ;) idk but its up to you if you want to spend that money bud
Username: Gibsonguy
Storrs, CT USA
Post Number: 214
rayray...why would you call the audison a corvette and the sundown a civic? what features/internals on the audison make it superior? and your analogy made no sense. you would take the corvette because you could make it better than the souped up civic. not to mention i doubt either is doing a 10 second quarter mile.
Kansas
Post Number: 2174
just an analogy didn't put much thought in it its the internet not a book report :D
Diamond Member
Post Number: 21440
Username: Denim
SoundSolutionsAudio.com, MD USA
Post Number: 743
From what I have read, the Audison's should be pretty true to power ratings, their quality is top notch. As Sundown power, well Jacob has reported 450w @ 8ohm mono, and upwards of 150 per channel at 4 ohm stereo from the 100.2
Kansas
Post Number: 2175
i guess if me stating my opinion in a unique way is me getting Pwned then i guess i did oh well
Diamond Member
Post Number: 21442
don't take it too personal ray. you do that to me all the time. didn't think you would take it like that. sorry my bad dude.
Kansas
Post Number: 2176
lol take it like how Chad you know were homies no one is upset here haha i said i did get pwned and i said oh well can't be perfect all the time right Chad ;)
Diamond Member
Post Number: 21443
Username: Nyyfan13
15 Mag USA
Post Number: 9908
Chad I thought about DLS and am still considering it, just didn't put it in the list.
I think I have my mind made up. :-)
Username: Gibsonguy
Storrs, CT USA
Post Number: 215
sorry ray im a dic* lol.
i just bought a sundown amp, and didnt want to be accused of buying a honda lol.
Kansas
Post Number: 2179
^^^^^^^ LMFAO this is the funniest sh!t ever lol well only cus Chad drives a honda :P but yeah no problem its all good and i think both Honda and Sundown are good companies so didn't think i was insulting anyone lol
Username: Nyyfan13
15 Mag USA
Post Number: 9912
Everyone is getting PWNED in my thread
Kansas
Post Number: 2180
John your a lil b!tch for not having the balls to make your own decision on your own equipment what a lil wishy washy b!tch :-)
yeah everyone is getting pwned John :-) just playing bud but i guess i'm convinced too get the sundown best bang for your buck
Username: Nyyfan13
15 Mag USA
Post Number: 9915
And to think I was thinking about just giving you my comps for free. Not anymore Ray. We'll see who gets them now.
Lol. JP dude.
But, yea I am wishy washyUpload
Kansas
Post Number: 2181
lol i was just joking John i think being wishy washy is better than being an impulse buyer ahhemm ahhemm
Username: Nyyfan13
15 Mag USA
Post Number: 9916
Lol. No names need mention :-)
Username: Ballinhigh11
whats subs and amp can i get for cheap and from where?
Post Number: 3712
ballinhigh11
Start your own thread and we will help you out.
Username: Nyyfan13
15 Mag USA
Post Number: 9929
^Word Joey.
Btw, update. I'm at $750 of the $1400 that I need to make before I buy anything. Couple more paychecks and I'm good :-)
