Old assassins vs new assassins
Username: Rosrock2000
AA Assassins, MI USA
Post Number: 450
I had tcabs made for the older versions and i thought they were 350 rms... and i see the new ones are 250 rms.. i may be wrong just tell me if i am. Just wondering if it would be ok to use the same boxes made for the older ones. thx
Username: Insearchofbass
Post Number: 9611
mark's designs may be vehicle specific....the only other variable would be if the thiel small specs are alot different....if they arent your ok but if they are its luck of the draw....a change in vehicle may or may not affect much....bottom line try it on progressive amounts of clicks on the head unit and see how it sounds....amplifier gains set correctly of course
Post Number: 451
is the rms different or the same?
Username: The_image_dynamic
San Diego, California
Post Number: 4135
Yes, the old version was rated at 350RMS, but has a "recommended" RMS of 250, which is extremely conservative. Here are the TS parameters of both 12's.
Old:
Znom 4 ohms
BL 12.3 n/a
Re 3.5 ohms
Sd 480 cm2
Fs 23.1 Hz
Mms 122 g
Vas 128 L
Xmax 15.5 mm
Qms 4.00
Spl 87.8 dB 1W/1M
Qes .41
Rec. Power 250 W
Qts .372
Rms 350W
Le 3 mH
New:
Post Number: 452
so should i put as much power as i did to the old ones to the new ones and so the boxes will work?
Post Number: 4139
Yes and yes.
Post Number: 9613
I would agree yes and yes....after running the specs and some guess work on tuning I think they will perform similar in your old box....let us know how it turns out
Post Number: 453
k thx guys
Post Number: 9614
yw
